Builds My HZJ77 Build (1 Viewer)
Very Nice! watching this also
you mention you haven't yet played with the fuel screw... if you didn't go wow, holy smokes on the first drive post turbo, play with it!
I am getting excited and figure it should make quite the difference.
I need to wait for the isspro guy to contact me because his "fix" wasn't a fix. Its programming related. I can't tune without a proper egt gauge.
I also need the vac line I ordered to come in so I don't constantly over boost. I am only going to be running 10psi max at this point, 15psi with an intercooler.
Ordering a boost comp for some tuning fun.
New Vac Line for the turbo was installed, it wasn't the issue.
Boosting 14.5 psi if I ride her hard, its usually around 10-12 with the way I drive.
Fuel hasn't been touched still because isspro apparently shipped out the replacement gauge to me on the 11th. I have had stuff further away in the states arrive sooner than shipping for Oregon....:bang: I am really wanting to play with the tuning.
Got this little goody in the mail today. This should make tuning nice and a bit more complicated.
Now have a dog too. I was the wet nurse on the 18th of Nov which was a cool experience, 11 puppies and all of them lived :clap: Her name is Fern.
I feel a cargo barrier design coming soon.
"Whatever Happes, Don't Say Awww" ;)
KCCO ... :lol: some good stuff on that site.
AWWWW, cute puppy, congrats. my guys love the passenger seat. they also enjoy being high enough they can lay down and still look at all the trees flowing past, i built a "set in" floor leveler that takes the passenger seat and extends it to the dash so they can't slip off.
So shes all tuned up:bounce: Had her going for the past week. :D
Did a pre-run with the working pyrometer as a baseline as I was waiting for it to tune the truck. 800deg F pre turbo max EGT. One and a quarter turn of the fuel screw later its 1100F pre turbo.
Boosting 14.5psi no intercooler as of yet :hillbilly:
Thoughts so far. Holy **** it is a a completely different truck. It pulls like a freight train and I am all smiles, this was exactly what I was hoping for. It definitely feels quicker than my HDJ81, how much quicker I don't know.I think it would beat it for sure, pulls WAY harder.
I still have to turn up the fuel some more as my max egt is 1100F but i lost my little socket while tuning on the side of the highway eariler on in the week. I will tune it up as soon as the rain stops, should only be 1/8 to 1/4 more of a turn on the fuel screw to get it to 1200F MAX EGT pre turbo. It stays at max egt for a very short period of time. Safe in my eye and with the amount of research I have done.
Smooth acceleration and power throughout the rpm band, its very drivable. There is a good sized hill that I have always driven at 80km/hr and been pretty light on the pedal just to go easy on the engine. I can now mat my foot to the floor and it will accelerate HARD up the hill from 80kms/h all the way to 110 at the top and about 1000deg F on the pyro (pre turbo). Its still got plenty of juice. I have a run to the ski hill Friday with a few good hills. Curious about the fuel economy and overall drive ability highway and hill wise.
Boost gauge will start to move at ~1100 - 1200rpm. and I can get it to full boost (14.5lbs) at 1500 rpm if I drive it like an ass hat. Usual driving 10psi at that rpm with some load and full boost at roughly 1800-2000 rpm with usual driving habits.
I get very simlar results to AdamB's Grunter install on his HDJ81.
1100rpm - 2lbs
1200rpm - 5psi
1400rpm - 10lbs
1500rpm - 15lbs
Holds that to over 3000rpm (I rarely rarely go there)
Flat highway
Cruising 80kms/h - boosting ~ 9lbs
Cruising 100km/h - boosting ~12 psi
The ceramic coating I think is helping too with cool down time. After a hard run around it will drop to 300 deg in seconds, I am shocked as my old hdj81 took way more time than that from what I remember. I am really happy I did this so far.
Stuff planned for a little later on this year:
Install the boost comp onto the pump
Injector servicing coming up (researching some stuff first on injectors)
Design a custom intake plenum and the TMIC (top mount intercooler) This should give more air to the cylinders and prevent leaning out cylinders 1 and 6. These seem to be the cylinders that go on the 1hz's with turbos. Should give more power too.
This should drop off the EGTs a bit more and have the ability to turn up the fuel some more. Apparently the turbo is good for 20psi max :hhmm:.
My final goal is to have ~150rwhp on skinny 33s, this should be possible with my fuel pump in my eyes as the 10mm pump on the pre 99 1hz engines max out at this range or a little above. I am looking at the idea of upgrading to a later model 1hz pump which has 11mm plungers or even getting a 12mm 1hd-t pump. This will only happen when I have to get my 1hz's pump serviced. Hopefully a long way away.
Graeme this turbo kicks ass, I want another one for my 75 at some point when I can afford it, maybe a little bit higher spec one. I am dreaming of comp truck power. I just picked up a CT26 off a 1hd-ft for it. In the mean time I might try and track down a 7mgte turbo and do a hybrid for some fun up to 18psi while the other truck mods occur.
Anyone wanting to fit one to a 1HZ this is the turbo to do in my eyes, as I said it is a COMPLETELY different truck now.
Though with the power increase my clutch is slipping a bit now if I hammer on it. Put the order in for an Exedy Safari Tuff today from John @ Radd Cruisers. This should fix the problem. The original clutch was a little funky since day one in this truck. I probably could ride it out for awhile but I'll just get it done next month or two when I do a few other maintenance things.
Nice work! Good review on the setup. Sounds like it has met all your expectations and more.
If I ever go for a HZJ I'll be referring to your thread for my build. :)
Got this heavy goodie in the mail today.
Edit my clutch is still slipping.
I still have to turn up the fuel 1/8 turn, we shall see what happens.
I get a kick out of the little animated clutch guy on the box.
The Japanese really love their animations, the factory glove box manual for my 77 came with some funny animations in it as well.
When you did your turbo/exhaust did you consider running the exhaust inside the frame rail?
I did though with the Vac shift transfer there isn't the room in comparison to the manual shift transfer. I plan on going that route on my 75 it simplifies things a but from what I can see.
