Looks great, Nick ! I like the way you installed the tail-lights into the carrier.
Keith there is tension on the latch when in the closed position but like you said, i wouldn't trust just that to keep it closed. The latch comes with a hole drilled through the body and the latch that you can put a locking pin of some sort in to make sure it stays closed. I plan on using this pin to make sure it doesn't do what happened to you. I'll probably run a locking pin like this:
McMaster-Carr
It looks like this mcmaster carr latch is a double locking latch but I don't know if it has provisions for a locking pin to be used with it. I like the idea of having a failsafe that I know will work, hence the locking pin.
McMaster-Carr
Hope this helps.
Nick
I'm slowly putting one together too. Where did you find the latch you used to close the swingouts? Can you give a supplier and part numbers?
Yeah...that was the one that I used for the 62, only the NON locker (I thought it WAS in my defense). Ill be doing a different configuration this time with the single swing. I want the outer end of it to be supported...sort of like your doing with the bushings, only on the far end and I may just use a pin in lieu of the latch altogether.
BTW, I really like the buckets you are doing for the lights. Pretty slick idea!
That can carrier looks HEAVY!![]()
Hey Nick
I have a set of these taking up space in my garage if your interested, PM Me..
Steve
