- Thread starter
- #61
Says the video is unavailable when I click on it....
Sounds like a leaking injector, if you cycle the fuel pump up to pressure but dont start it, let sit for awhile and check fuel pressure gauge, it shouldn't drop much.
I assume you have a fuel pressure gauge ? #1 best diagnostic tool for an LS IMO. I have a mech fuel pressure gauge in the cab. Yup, could leak and soak everything with gas, hasnt in 21 years. Knock on wood. The other suspect would be the computer you are using, not familiar with aces, I run a howell stand alone harness & comp which worked outa the box.
I think it’s working now.Says the video is unavailable when I click on it....
I don’t have a fuel pressure gauge. I’m sure I could borrow one from a buddy though.Sounds like a leaking injector, if you cycle the fuel pump up to pressure but dont start it, let sit for awhile and check fuel pressure gauge, it shouldn't drop much.
Not sure, it’s not consistent either. I can’t get it to repeat every time.That’s an odd sound. Mine makes a similar (but VERY brief) noise when I first turn the key on. No chance it’s the TPS or IAT sensor up on the throttle body?
Yes felt around multiple times. Also used a hose up to my ear and went around the entire intake right there. All relays are in the cab. Pressure regulator is on the driver side in the middle of the fuel rail.Have you felt around while that noise is going ? Like touch the coils, injectors , any relays sitting up top ? is the pressure regulator making that noise ?
I’ve set my idle to run at 650 since I’m running a TH350. I’ve had it down to 740 but that’s it. I have almost full programming functions with the Aces kit. Everything seems to be reading right including fuel pressure ratios and all.I wouldn’t think that a leaking fuel injector would cause a high idle, but I’ve been wrong before. My LS idles at 500 RPMs with the factory computer, but that’s where I had them set the RPMs. Has your engine ever idled lower than 850 RPMs? Can you adjust the idle with your controller?
Have you sprayed starting fluid or similar type of fluid around where you suspect to have a vacuum leak while the engine is running?
Are you running the OEM fuel regulator or an external one? Not sure what fuel pump you’re runningYes felt around multiple times. Also used a hose up to my ear and went around the entire intake right there. All relays are in the cab. Pressure regulator is on the driver side in the middle of the fuel rail.
It took me calling Aeromotive to determine that if you’ve got an external regulator you HAVE to block off and remove the OEM unit on the fuel rail. Not sure that’s the issue here but I had mine plumbed wrong for years.
