Cut it in half or drill out the center. They are supposed to have a nut on the end to hold them together. Dang PO looks to have gotten carried away with his welder![]()
OK. That's what I thought it looked like, too, but I'm a novice in these sorts of things. I wonder if the PO was attempting to eliminate "play" in the handle.
The days they do move by slowly.
Spent an hour on the Troopy this weekend puzzling over some more wiring issues given to me by the PO(s).
When @65swb45 looked over the truck many years ago he noted that there was an unfused wire going directly from the alternator to the positive terminal on the battery. I've studied the wiring diagrams and I can't work out what that wire was meant to do or replace.
I took a chance and decided to remove that wire temporarily (from both ends) and then tested things. I turned the lights on and measured as the voltage on the battery slowly drained below 12V, then I started the truck and watched the voltage closed my back up to about 13.3V.
That suggested to me that the alternator is charging the battery without that wire. But even though PO's can do weird/dumb things they usually have some reason for doing what they do. @bj40green do you have any thoughts on what purpose a wire directly from the alternator to the positive side of the battery might serve?
From which terminal on the alternator?
Rudi
Thomas,
Just an aside: was that just a slip of the finger when you referred to the Previous Owner(s) (PO s) as a POS ?
I think you may have coined a new way we can refer back to those folks who cause us all so much extra hard work !
Terminal B.
I knew I should have gone out to the truck to check and post that information with my original question!
FWIW, all of the other wiring at the alternator appears to be stock and matches to my FSM wiring diagram.
I should also mention that over on the driver's side (RHD) the two inline 5A fuses that should go to the ammeter are disconnected. The W-L is actually disconnected, and on the B side the fuse is simply bypassed and the wires are spliced together on either side of the fuse.
And as I type that while looking at the FSM diagram, I think I see why the B+ on the Alternator was connected directly to the + side of the battery.
The heavier gauge W-L off of the B terminal of the alternator normally connects to the + side of the battery through the Fusible Link and through the B--->5A--->B--->Ammeter--->W-L--->5A--->W-L path.
Without the fuses to the alternator and without a fusible link in that location, there is no path between the B terminal on the alternator and the + terminal on the battery.
There are three fusible link wires that come off of the + terminal on the battery which I will now need to chase in order to understand if the system I have is safe at present.
