- Joined
- Sep 21, 2007
- Threads
- 233
- Messages
- 3,919
That wagongear lid is on my priorities list! I want to make something custom but I know his is better! lol
Johnny, have had good luck with the CSF's i have run over the years, heck my 60 that you got the body from had one in it for years.
Feel like taking a close up of that seal? I have an annoying clunk coming from the hatch/tailgate interface... and that looks like it would be a good fix.
I'm glad you cleared that up, I knew you got yours right before I got mine and it's been in BT for at least two years. DocWonderful things Kevin comes up with.
nice!nice!
cool, sometimes it just makes sense to let others do some work on the rig...
I'm very happy with my alu rad, cant remember the brand. Using a temp controlled 16in spal, without a shroud.
Enough for most stuff, but i like beeing able to shut it off while crossing deep water or mud.
Thats the main reason i want the spal. Another benefit is full cooling power still at engine idle.
And easy access to engine front.
Without the shroud it's easier to clean out mud, since i have the IC close up to the front.
At speeds above 20km/h its plenty cooling, but when slow and tucked with mud it can get a bit hotter. need to figure out a "easy to remove shroud" that the spal is bolted to, so i disconnect the fan, pop the whole thing out so i can clean mud out.
I used a dakota digital controller for my tauras fan. I like it so far.
Another unit is the Spal PWM, does mostly the same, supports 24v.
Just sharing but I had a Spal controller that started an electrical fire. Luckily I caught it before irreversible damage could be done but I would make sure there isn't a better option out there.
Here you go, let me know if you need more. It goes over the uppermost lip of the tailgate ( when closed ) about 1/2".Feel like taking a close up of that seal? I have an annoying clunk coming from the hatch/tailgate interface... and that looks like it would be a good fix.
The mechanical fan is just in there on that picture for testing purposes.
So the spal is out at that very moment, the picture was taken for other purposes.
The spal is a pull-fan. Prices on re-coring or stock rads are so crazy here.
Aluminum, bigger, badder, better. Others might hold that against me.
In the end there are pros and cons to both. I just kept a stock replacement rad because I never intend to put a v8 in mine. If that was in the works I would have probably upgraded.
The thing i like about these controllers, is the ability to run at 50% fan speed, and increasing speed as temp rises. That nifty setting stresses less amp out of the fan start up, i can see mine pulling almost 30 amps when it starts from 0 to 100 %.
I went with this solution, because its safe, easy to fix if anything happens, and one tenth of the cost of a controller. But i still want a controller.
You're going to put a 6BT into your 60. Why would you have not upgraded the radiator when you had the chance?
My first choices are:
