Last week I got a random missfire code for cyl #2
Stumbled at idle, but cleared up when driving
Pulled the spark plug wire at the distributor as a quick test while on the road and it stumbled some more, then smoothed out when I held it against the cap.....
Pulled the #1 and #2 plugs and they had a bit of ash on them, but not saturated with oil, fuel or coolant
(I've been putting off replacing valve seals for a while, so I was expecting worse)
Decided to swap the plug positions, clear the code and drive until it comes back while I wait for new plugs in the mail.....
Code came back about 50 miles later for #2 missfire again, so the plugs wasn't the issue....
Fast forward to today....I replaced the plugs (OEM of course), but still had a stumble at idle.
Pulled the #2 cable again and the cylinder was definitely dead
Did a quick resistance check on the plug wire and it passed (wire set is only a couple years old....OEM as well)
Grabbed my stethoscope and both #1 and #2 injectors sound like they're ticking as they should.
Tapped on them, but it made no difference.
Pulled the injector plugs, grabbed my meter and both injectors test out at ~14.4-14.6ohms
That's about as far as I got as it gets dark way too early nowadays
Plan on pulling the spark plug again to see if it's fuel soaked (doubt it), but right now I'm just assuming a clogged injector
Before I pull the rail, is there anything else I should look into?
(I've been putting off replacing valve seals for a while, so I was expecting worse)Decided to swap the plug positions, clear the code and drive until it comes back while I wait for new plugs in the mail.....
