that is awesome!
Dylan
Dylan
I am very interested in a MT cage. I have one minor question, for the older pigs with a dash mounted ignition, will the cage block the ignition?
Yes the 55 cage will be out before April.
Mark
The 55 cage will be based off the 60 cage design. Just some added tweaks to make it fit the FJ55 body lines. Along with our signature A pillar design around the dash.
Will this be designed to mount to the frame, unlike the 60 series bolt in & weld "kit"? Just curious to know if y'all think that's *sufficently designed that way.......
LT,
Thanks for making a cage for the 55! I like many others am very interested. If you have a minute could you please answer a couple of quick questions?
- Will it work on the early models with the key on the left side of the dash?
- Will the cage need to be finish welded in the truck?
- Is there anyway you could incorporate an S/S coupler or clamp so that the cage could be made removable? Easier to install, weld, and paint/finish.
- Who is first in line?
Ryan.
