Hi Guys,
I'm Adam, from the UK. i have a winch challenge Land Rover based tube buggy with a VVTi 1UZ and 80 series axles
I have already popped a stock birf so upgraded to RCV axles and birfs, now i have stripped the front ring & pinion (was expecting it to happen at some point)
it was stock gear still running a crush tube pinion spacer, could have played a part.
My options are: rebuild the 3rd with Nitro gear R&P and solid pinion spacer and hope it holds up but potentially be back to square 1 after the next event OR
build a hybrid front to take a 9.5" e-locker 3rd.
I would really like ruffstuff or Diamond housing but the cost to get one sent over to the UK is a BIG hurdle!.
I have been offered a rear axle from a BJ45 for cheap, i'm waiting to hear back from the seller to see if it has a bolt-on diff pan, which i believe will make fitting it in the front simpler. i would still need to get another e-locker 3rd but the stock 45 3rd would be handy as a spare
Will 80 series knuckle balls fit in the 45 casing? will the 9.5" 3rd be wider meaning the inner axles will be too long to keep same width as stock 80?
Will a 9.5" actually be much stronger than a rebuild hi-pinion 8"?
D60's don't exist in the UK so please don't suggest that!!
Thanks
Thanks
