LX470 HID RETROFIT PROJECTOR BRACKET (8 Viewers)
Working through a MicroD2S install right now - the Morimoto XB35 igniter hangs out the back by about an inch. In order to retain a water proof/resistant housing, I designed and 3D printed some custom tail caps out of ABS. These twist-lock and use the factory o-ring, and are designed to work perfectly with the grommet that comes on the XB35 wiring. Super happy with how they came out!
It's great to see creative additions,
That cap works well, I've used that same cap. You should have use JB Weld on the bolt heads prior to installing, which will allow you to tighten the nuts from the front when making your adjustments and leveling the cut off. After adjusting, remove the headlights and seal them up . Small observation.
Ahh yes. I’ve had to buy new butyl and redo it the right way but totally worth it. The nuts are now glued and adjusted correctly.
Added a layer of laminx and a whole custom harness utilizing this free fuse placement on the battery connection I believe all US 100 series don’t utilize this open area. Fully integrated system and fully sustainable retrofit.
No flicker and has been quite reliable. I have also did the high beam mod to have access to
More light.
Fuse:(https://a.co/d/4nlmz6Z)
The finish product definitely modernizes this 25yo rig. Thank you Luke for supplying demand. It’s been a year in the making from being out of stock for the brackets and finding headlights with the Lexus green tint. The tint and D2s combined with Morimotos micro and their AR coating make the eyes look like crystals on or off. I personally believe no led can replicate the effect of D2S in this combo. I also have glass lenses and bulbs are ~3000k
