Pints at a local craft house? Or at Prospeed on Cutten road.Definitely down to meet up in Houston to check this out in person.
Premium is a requirement. Costco here is $2.77 for 93 octane. Gas mileage stayed the same.Is there a requirement for premium fuel with the supercharger?
Also, did you go stage 1 or stage 2?
Also curious about your mileage?
Understood that the LC200 is not a Prius but I like the 19mpg I'm getting now and wouldn't want to lose 20%.
Oops, stage 1.Which stage did you go with?
0Mpg?
Stage 2 is less “bolt on” and requires a few more mods to make the whole thing work.If stage one feels that nice, stage 2 must be bonkers.
I saw the difference in the pic between stage 1 and 2 seem to be new injectors. I wonder what else it requires?Stage 2 is less “bolt on” and requires a few more mods to make the whole thing work.
Stage 1 is what I’m ordering. It’s bonkers enough for me in a 3 ton SUV.
It doesn't mention a reg in the kit, just a pump. Seems like from the video, the Stage 1 is running just fine.I'm excited to see more progress with force induction on this platform.
Anyone run one with a wideband? Would be interesting to know if there's enough fueling for the Stage 1 HP level. As a previous tuner, I suspect it may need at least a rising rate fuel pressure riser to provide enough fueling with stock injectors.
Sounds like this Houston meet is growing... Should we do the Texas thing and select a Buc-ees somewhere (IYKYK)...@Tex68w @radman any meet ideas? I don't drink but feel free. Also, somewhere more central than Prospeed.
This stage 1 kit includes an upgraded DeatchWerks 340LPH fuel pump to be installed, as well as a jig to modify the factory fuel pressure regulator to increase fuel pressure.Hopefully they've done their research and this is true. From my days of tuning for forced induction, I wouldn't assume, and I have my suspicions that what's provided in the kit doesn't create enough fuel capacity to support the added airflow. Pump only goes so far. Actually, the fuel system is likely at a disadvantage with boost and the setup is relying on fuel trims to cover.
It'll probably run great and fine for the typical enthusiast that does short pulls here and there. Given the wrong variables, perhaps with load, on an extended pull up a mountain, on a cold day with max boost, and things may just go too lean and fall apart. The engine will feel great, just until it doesn't.
Short of wide-bands, perhaps the OP can monitor fuel trims. It'll be some indication, but still won't provide the whole picture with full throttle and open loop.
I have confirmed that a tune is available for the 2015 LX 570 via HP Tuners. This is technically unofficial, as HP Tuners does not list ANY Lexus vehicles in their support list. The vehicle does register ok and shows a tune is support when plugged in. Confirmed with several tuners.
I ordered an HP Tuners MPVI2+ (latest model) so that I can take plenty of logs to see just how well this Stage 1 setup is. In the future, I will be upgrading a few components. I have ordered the American Racing Headers 1-3/4" x 3" Long Tube Headers w/ High Flow Cats. I will be upgrading my fuel injectors with either DW 650cc injectors or 750cc Bosch injectors from Prospeed. The DW 340lph included with the stage 1 kit will likely need to be upgraded to a 450lph unit. The modified fuel pressure regulator will need to be swapped back for an unmodifed unit; luckily these run pretty cheap at $49 online. Contemplating getting an AFE intake or perhaps a Magnuson air box lid. Not sure. This will require a tune of course!
