Bolt each side to a board for leverage. Soak the hinges well in PB Blaster and then see if you can break them free. Has worked for me with seized hinges in the past.Windshield hinges are kind of seized, should I just soak em in varsole?View attachment 1889154
Weird! Mine doesn’t have it.FWIW - My '77 (12/76) FJ40 has 416 stamped into it's vin plate.
That sounds like some good advice, thank you! So we have lowered our pressure, and 20 degree temperatures are finally here and our coats are finally looking better!Lower your pressure. I found too high of pressure can cause some orange peel, but please keep in mind, orange peel has many causes. Weather, paint viscosity, proper hardener (fast, med, slow vs temp) and not waiting for proper flash time between coats can all cause orange peel. I found if I take my time, keep the pressure low, spray thin coats, that usually keeps the orange peel to a minimum.
Now with all that being said, shooting a base clear system, I don't care...
As I will shoot 3-4 coats of clear, then cut and buff to eliminate all orange peel regardless of how careful or not careful I was with all of the steps.
That's why I prefer base - clear.. It;s more forgiving. (even though I still shoot single stage about half the time)
Theres a good chance I will put factory stripes back on, but I’ll make a better decision once it’s all back together.Looking great! Any thoughts on putting stripes back on (except ones that look closer to OEM)?
