Hi I’m looking for a 2 groove crank pully for my 1970 FJ40 and I’m not sure if I have a 2f engine or a f engine
Yep it’s a f View attachment 2186410
Why does that red wire go to the block?
There is a flat block just behind the distributor that has a number stamped into it, if it starts with 2F, well, you have a 2F. If not it is an earlier engine, by the looks of things, I would bet cash money that it is indeed an earlier engine.
I guess red is the new black for grounding cables! I hope an under informed helper doesn't hook up jumper cables the wrong way..I think that’s the ground wire from the battery, mine had that too. Is there a better place to connect it?
Change that metal fan out for a plastic one, @3_puppies just took out a radiator last year, he's not the first, won't be the last either.
Make it safe before you make it go.
the thermostat housing above the WPsomeone has done a # on that engine bay,
thermostat housing?
electric fuel pump?
no fan shroud
fan too close to rad
Toyota water pump??
heater hose is kinked off the lower rad hose
lower rad hose looks closed off by mis-alignment
maybe the pic, but the steering shaft by the oil filter looks bent
PS pump looks out of alignment
That steering shaft also looks like 5 pounds of chewed bubble gum. I'd put some serious thought into that moving on.maybe the pic, but the steering shaft by the oil filter looks bent
