Just ordered the ones linked in the original post. Just to confirm, these are straight plug and play correct? I've been a bit confused with all the back and forth in the thread. My '95 is completely stock headlight setup. Can I just swap these for the original bulbs?
Correct, I ordered the ones linked and it is simply plug in and go. The light output on these still surprises me every time I drive at night.Just ordered the ones linked in the original post. Just to confirm, these are straight plug and play correct? I've been a bit confused with all the back and forth in the thread. My '95 is completely stock headlight setup. Can I just swap these for the original bulbs?
Saw another thread about the importance of a beefier wiring harness for light output / performance. Can I assume that the efficient magic of LED headlights mitigates the need for something like a SLEE headlight wiring harness (http://sleeoffroad.com/products/harness_main.htm)?
About to finally pull the trigger on these..
I have a set of the Cree low beams that arrived today. They appear to have external drivers. Do i need them? Has anyone mounted these, and if so, where?
What exactly does the slee harness do?
LEDs need a driver to function properly. Whether it is a separate piece, or integrated into the back of the light, it needs to be there. So, yes, you need them. Just mount them where they won't be in the way of anything, and where they are as protected as possible.
The Slee harness provides more power to the lights by giving the current a shorter, more efficient route from the battery to the lights. It has heavier gauge wire and bypasses much of the small, lengthy OEM headlight wiring. The result is brighter light and a happier driver.![]()
I agree that the LEDs are far from the fine tuned beam pattern of the halogen bulbs, but in my 80, it lights up the first 30 feet in front of my car much much better than any halogen. In dark, wet autumn nights, the difference is significant and critical. I have seen what it looks like to oncoming drivers - and the glare is not as bad as aftermarket HID.Race Sport was the domestic brand version of these bulbs I tried, was horribly dissapointed in the glare produced by these bulbs!
They are bright, but fail to focus the light correctly against the reflectors and produce obscene amount of unfocused bright-as-h*ll glare. I switched back to the PIAA 9006 direct replacement bulbs.
I am running stock Lexus headlamp assemblies FWIW, not DEPO's or any kind of fancy projectors.. I imagine with a projector lens these bulbs would be fantastic!
I contacted VLED about buying their products and the semi rude reply was enough for me to spend my money elsewhere. If you don't have time to provide good customer service then I don't have time to spend my money with you. Oh well.....I agree that the LEDs are far from the fine tuned beam pattern of the halogen bulbs, but in my 80, it lights up the first 30 feet in front of my car much much better than any halogen. In dark, wet autumn nights, the difference is significant and critical. I have seen what it looks like to oncoming drivers - and the glare is not as bad as aftermarket HID.
Thanks, should be fixed now.^^couldn't see the video, says private?^^
