LED Headlight Install, 2000lm each no external driver
I'd be taking the lumens claims with a grain of salt. I assume just like the cheap Chinese flashlights, the lumen claims are grossly exaggerated. Grossly exaggerated.
Yeh agreed, mine seem to be brighter than stock so I could of gotten lucky. I wish there was a way to measure lumens at home.
Yeh 60w per set is 30w per bulb. If they are 60w each then can produce 8000 lumen each which is blinding if used as a low beam. Even as a High beam 8000lm is a lot. You have a link to the details on the set you got? Something isn't right
I never believe any of the lumen claims. It is suppose to be 8000 lumen for the set which would be 4000 per bulb. Still not very likely.
http://www.ebay.com/itm/121347809406
Mine should be here today so I'll replace just one bulb and see the difference. I'll try one of the Lumen apps too but I'm guessing they are about as accurate as the Chinese sellers claims.
Well they're bright. The app was screwy as I figured. It was reading 40000+ lux at 3 ft. I don't know what correct standard distance is. I thought it was only at one foot but I may be thinking SPL for sensitivity. None of the top 10 apps displayed as lumens even when it was on the name of the app. All displayed lux.
Another app was reading 16-26000 lux. Again pretty random.
Just high. I was worried about too much glare with LED low beam. I may go ahead and get them though because the LED high beam seems just as tight as the halogen.
I have not seen any glare, things are actually clearer to me than the Halogen. People see things differently so for me the lows are great.
I was thinking glare for oncoming traffic. The H1 LED is lined up perfectly with the center of the H1 halogen. If it is made the same way in the H4 there shouldn't be any glare and the beam pattern should resemble the halogen.
Mine arrived today - the original, self contained Ebay types. Will install and report.
Also in the market for a nice set of highs if people are happy with anything, i.e. the VLEDS above - would be willing to pay more for quality LED highs in lieu of mounting more lights on the truck.
Gonna wait on getting the 3 Chip so those that are in line for my current LEDs sorry for the inconvenience
So this post is pretty old, I think we can get a good idea of how they hold up? So I just order 4 and use the same way for both hi and low beam?
no but I just ordered a pair. d^#n Amazon Prime :)
will post review this weekend
those are apparently for the high beams so i would think they would be too bright for low beams? what do you guys think?
If oncoming drivers veer off the road they are too bright.
Check your aim on a garage door at about 25' to see where they are hitting.
Cutoff should be about the top of a headlight on a car.
At 25' the top of the beam should be 2-3" lower than the top of the beam at the headlight itself. Just make sure they are pointed DOWN, and as long as they don't scatter the light too bad you will probably be OK. If the light is too scattered to even see the top of the beam, then the lights are a nuisance on the road.
I was basing that comment off the lumens that they put off. I was thinking for low beams you wouldn't want more than 2,500 lumens per bulb. Sound right?
Secondly, the socket is the same for the 9005 and 9006 right? It's just the designation between high beam and low beam... that's what i'm guessing?
