No spark
USA Tennessee
Hey I am new here I have a 1991 Land Cruiser 3FE and I have no spark the cel does come on. I have replaced the coil, distributor and control module and still no spark I have been reading about this problem and keep seeing something about the cps and can’t find out if my 1991 has one and if it where is it and thank u in advance
Ps I am a disabled man with only one leg and can do to much
So, you DO have a CEL when the key is in the RUN position with engine OFF?
What brands did you purchase and install for the coil, dist, control mod?
How did you verify no spark?
Have you addressed the low hanging fruit like wires, cap, rotor?
Have you checked for continuity between the distributor connector and the ECU? This is all documented in the Toyota EWD and FSM, which are available to download in the resources section.
