LED Headlight Install, 2000lm each no external driver
in Jersey near Philly YO!
So after researching for over a year my patience has worked in getting it right, so i think, on purchasing and installing LED bulbs for the headlights. I found a set that seem to fit the bill just right. I got 2000lm each bulb and no external driver needed. These are internally fan cooled and use 2 CREE-XM-L2 LED's per bulb so there is coverage inside the entire housing. The 9006 halogen is about 1850lumen so I wanted close and this is close and a slight bit brighter.
$60 set
http://www.ebay.com/itm/151301569147?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I found that these are IP67 rated which means;
"Ingress of water in harmful quantity shall not be possible when the enclosure is immersed in water under defined conditions of pressure and time (up to 1 m of submersion)". and "No ingress of dust; complete protection against contact (dust tight)"
Also I started the truck with them on and unlike the halogen they don't dim the slightest if you crank the engine with them on.
They were packaged well and came in a foam type of wrap which was tough to get open but served its purpose.
The locking tabs are smaller and i thought they wouldn't work but they do fit after a little jiggling and the plug will be facing down and at bout the 5 o'clock position. I tugged and wiggled and felt no freeplay so it seems to fit nicely.
Drivers side. note the plug wire position. The passenger side fits perfect ly behind the overflow bottle with about 1/2" to spare.
Difference between the standard and LED, It really makes a hug difference. Street signs glow and I can see every bump in the road.
Before
After
Few more pics. Hard to get a good pic but I have to take some other night shots since I have to re-aim the housings. Otherwise you can see the color difference somewhat in this pic.
from the passenger side, comparison
Color looks much more useable by human eyes. The stock lights look about 3,200-3,400K & those LED's look to be about 4K. Am I right? How much brighter do they appear, say, 75' down the road?
Here are the specs, I need to aim the housings so I'll report back after I do that
DESCRIPTION
Product: 40w 2000lm 9006/HB5 Car Cree LED Headlight Kit Lamp Bulbs Light All In One
SKU: LEDHL-AIO-9006-40W
Condition: 100% brand new with original retail package
Certificate: CE, CCC
Package includes:
2x 9006/HB5 High Power genuine CREE-XM-L2Bulbs
2x LED cooling fans(built-in)
2 years warranty service
Item Specifics & Feature:
LED quantity: 4pcs (each bulb has 2 LEDs)
Power input: 12V-24V vehicles
Material: Aluminum
Color: Xenon White 6000K-6500K
Power: 40W
Lumens: 2000Lm/per bulb, 4000Lm/per kit
Beam Angle: 360°
Lifespan: > 50,000 Hours
Low Voltage Protection, High precision Constant Current Driver Chip
Great for ANY Application
Built in IC Circuit (Current Regulator)-Prevents LED Damage from Voltage Variations & Spikes
60% Less Power Consumption
Easy Plug and Play Installation
Sure hope the Chinese cooling fan doesn't go out and burn down your truck. lol. I am kidding obviously, but I would bet the fans die fairly prematurely. Can you feel them moving air and cooling?
Yeah, I saw all that. No listing of the Kelvin temp. of the LED's & it's hard to tell via a computer. I thought maybe you knew. Looking forward to more pic's & input!
Interesting. May have to do this pending short term report.
Nice find and write-up. Let us know your opinion on how much brighter/better they are at night. Are you using these are for the regular lights not the Brights or both?
I didn't try that yet, will tomorrow :)
Color: Xenon White 6000K-6500K Look OEM color. Very nice color actually
Right now they are just the lows. They are new design with driver in the housing and i couldn't find the 9005 with internal drivers.
another option is to use HIR's, plug and play (for the most part) and they put out lots of light:
Here's the comparison:
Low beam stock: 9006, 12.8V, 55W, 1000 lumens
Low beam new: HIR2, 12.8V, 55W, 1875 lumens
High beam stock: 9005, 12.8V, 65W, 1700 lumens
High beam new: HIR1, 12.8V, 65W, 2530 lumens
are those LED's 2000 lumens on high beam?
Nope low beams 2000lumen per bulb 4000 lumen a set
yeah but I think all the ratings are based on single bulbs for comparison purposes, IE: 2k lumens for your led's and 1875 lumens for the HIR's I mentioned. I don't think you double that because you are using 2 headlights.....
do they make high beams that are higher lumens?
Sorry, I missed that! 6500K has a blue hue but those don't look blue @ all.
Well on each bulb they are marked 2000lm 2000x2 bulbs is 4000 lumens total.
Yeh they make 6400lm set so 3200lm each. so should be sufficient i would think
when switching to these units is it necessary to change the headlight lens? this is the main reason why I have not gone the HID route as HID's tend to "throw" light in every direction if you are not using the right lens for them. Is this the same scenario when using LED lights like these?
Stock housings. Seems just the same pattern as the halogens
Stevensnj is correct. The headlight housing is what dictates the "throw" of light. Its problematic with the HIDs and the stock housing because since they are diffused, the light is "thrown" in the same direction as it would factory but at a much higher intensity, hence the name HID. I'm not sure if there is a specific amount of lumens until you should switch to projector lenses but you can always experiment on your own. Increase the number of lumens until you have had enough people :flipoff2: you off.
I had a low beam bulb go out this week, so I just ordeed a pair of these up.
Steve - do you have a link to the high beam bulb you found?
