LC & LX470 Tesla Style Screen Radio Upgrade with Climate Control: General Discussions (37 Viewers)
Has anyone updated the firmware for their px6? I have one from phoenix automotive (unsure if there are other variants) and the firmware is 8.1.0 from 2019. I'd like to upgrade it and see they have some newer "px6" firmware out there...just unsure if there are specific firmware file for specific vehicles. Their latest file is from Jan 2021 but it doesn't have much detail on what it is or application. Thanks!
Hi All, planning out mods for a to be purchased LC100 or LX470.
As the trim pieces for the LX470 version only appear to be available for US/LHD versions, I'd be interested to know if anyone in RHD markets has used LC100 side vents instead in order to keep buttons in the normal locations.
Thanks
Hi All - Just got my PX6 from Phoenix and have it mostly installed. However, i'm having a couple of issues and would appreciate your help!
1) getting this annoying "beep beep beep" that won't go away unless the radio is on:
2) I can't get the AC controls to work. They worked until I went into the advanced menu to change the logo to a LC and now they don't.
I also have this harness that doesn't seem to plug in anywhere?
Untitled by jeff elliott, on Flickr
Thanks
Hey bro,
I did an install last weekend and ended up just trimmining the original LX trim back. It came up pretty well. Only mounts on the oustside though not to the unit but you cant tell and it doesnt move. It was a bit of messing around though. Used a 1mm cutting disc to make th einitial cut and then a danding disc to level, bevel etc. Bevels were the key to making everything line up nicely. A few other old mounts need to be ground away on the lower inside too.
I think I saw one seller on AliExpress that has a ship from Australia and they had trims that looked like they had the 3 holes in both trims and a blanking plate.
It looks a bit better than this now as I bent the PX6 brackets to make everything line up nicely. They are pretty flimsy,
Almost done! Just got the firmware from Sergey installed and its a huge improvement! Seriously, spend the $100 - its totally worth it.
Just to recap what I‘ve done so far
  • Installed PX6 (duh). Utilized Phoenix tech support to resolve some issues and they were great.
  • Replaced factory amp with the Kenwood suggested earlier in thread and promptly blew my 6” sub 😈. The amp bypass harness from Metra (70-8116) was perfect and kept me from having to tap into or cut the factory speaker wiring harness. Plug and play. Ran new power wiring for the amp and everything works pretty great with some minor issues I’ll list below. Can’t believe how much better this sounds even with the 16 year old factory speakers.
  • Installed SiriusXM Commander receiver
  • Was unsuccessful in tapping into factory camera wiring
  • Got Sergey’s software installed
Questions/issues:
  • I have the interference noise that tracks up and down with the RPMs. I assume this is a grounding issue but not sure if its at the PX6 or the amp. Amp is wired directly to the battery and negative goes to the body. I think I remember reading something about adding a grounding loop? It’s slightly annoying and need to resolve this at some point.
  • I assume my taps didn’t work or something with the back-up camera. The trigger wire isn’t even working. Assume I’ll just have to go with a replacement which isn’t a big deal.
  • How do I get the outside temp to show on the display near the clock? I’ve seen this on others. Not sure why mine isn’t showing
  • Is there a way to set up CarPlay so you can continue to listen to the radio or aux while also using CarPlay? When the CarPlay app turns on it automatically goes to the music app on my phone.
  • How do I get the PX6 to use my phone as the data connection? Do I have to add a SIM card to the PX6? I didn’t even see that as an option.
Overall, this was a bigger project than I expected but a huge face lift for my ‘05 LC. Next I will replace the factory speakers and install an aftermarket backup camera. Thanks again for all the info that has been provided in this thread. I can’t imagine taking this on without the wealth of knowledge and experience you’ve all shared.
Hey bro,
Any tips on getting the wood trim to fit flush like in the photo? I trimmed and installed mine today and the panels kind of want to stick out and not want to fit very well.
@wvanrite RE: ground loop, how did you connect the HU to the amp? This is the reason I went to the Kenwood, I chased the ground loop installing multiple clean grounds and filters to no avail. Using the RCAs from the HU and a solid ground to the amp I have no ground buzz (used existing speaker wires from amp). HTH -
Its all about getting the bevil angle correct from what I found. The trim goes towards the screen on an angle so you have to sand or use a file (I used an angle grinder with a sanding disc) to get the side of the trim you cut to match the square edge at the screen. Its probably at about 45 degrees from memory. I also had to remove some of the back of the trim where it clashed with where the mounting piece on the head unit. Yell if you want me to rip one out and take a photo.
I'd certainly love a photo if possible! I've cut some of it out so far
@tucker74 - I actually did exactly like you and used RCAs from the PX6 to the new Kenwood amp. Also reused existing speaker wires. I’m hoping a filter on the new power wire to the amp may resolve the issue.
Hello Mud Community,
Over the last 9 months there has been some great headway made on the ZhiFang 12.1" Tesla style touchscreen radio with integrated climate controls. There are a few dedicated threads to specific installs and I figured it was about time to create a general discussion forum as lots of good install info if getting buried in these threads.
For those of you who have not seen this yet it seems to have started here: Tesla style head unit - has anyone seen this?
Specific installation experiences have been documented here:
Successfully installed a Tesla Style headunit into a 2005 LX470
"Tesla Style" found for older LX470/LC100
2003 LC Tesla Screen Install Write-Up
Here is what they look like: ( mistered123 I hope you're ok with me snagging your pics for reference)
BEFORE
2027404
AFTER
2027406
The quad core units were the first batch to come out late last year. Part #s are ZF-1301S. These used Android 7.1 and (once the wiring issues were worked out) they worked pretty well. Overall the hardware and OS where described as a little clunky, but a definite improvement over the original touch screen radios and cassette decks.
The six core units (PX6) are the latest batch out as a release of this post and are pretty good. Part # for the LC version is ZF-1301X. These are not showing up on the ZhiFang website yet, but they have ZhiFang's name on them. They look to have the same cables as the original quad core units but have worked through most of the wiring issues. Interfaces are crisp and fast with the only general complaint is the amount of time it takes to start up once you turn your key on. This is typically around 20 seconds. AC controls work great and utilize existing Toyota circuit boards as part of your original radio.
I'd like to send out BIG thanks to mistered123, LX470MK, Swainbuilt, Wetwillie, revoked, loeky, Ell Ex & all the others that have contributed so far with testing and Q&A.
These units are sold by a variety of online resellers, but they seem to be made by one manufacturer in China. They don't come with assembly or operations instructions...AND the technical support is lacking. Some have been buying from a US based radio shop, but it sounds like they were just buying these radios in bulk from China. Here is where you can find the PX6 chip set radios online for purchase:
The only thing I can tell different between the LX and LC versions is the additional side trim for the air vents as the LX trim tends to be in three pieces (one running the full width of the cassette deck) and the LC already has the appropriate vents.
Ell Ex has done a successful full install of the PX6 (6 core) units with Android in a 2006 LX470 with ML amp and custom apps. I'm in the middle of a full amp and speaker replacement with a 2004 LX470 and the PX6 unit. A few others have been working on 2003 and older installs. I've heard of a few people wanting to try these with non-nav (dedicated AC control version) 100 series trucks, but have not seen one yet.
The 2004 and newer seem to be plug and play for cables (once you figure out where they all go). There seem to still be a few extra plugs left over (3 in my case) that may have been part of the factory test.
The 2003 and older units are needing either another harness from the manufacturer or a few wire splices to work. There was a request for the "Top Model" wire harness for these truck to avoid splicing, but I cannot confirm its the final solution.
No confirmations I can find yet for getting the factory backup camera working. I'm looking at installing a new HD camera now to replace the 16 year old factory one. One in the back and one up front hopefully.
I am hoping to write up a first draft of an installation guide for my experiences on a full amp replacement and am willing to share with others to alter for 2003 and older versions as well as ML integrations/tips/tricks.
My hope is that this can be a source for good general information on the radio installs, applications, mods and troubleshooting and the model specific threads can serve those specific needs without getting cluttered with off topic discussions.
Hope you all find this helpful. I'll try to get my install guide uploaded soon.
PLEASE ADD YOUR EXPERIENCES AND COMMENTS.
11/05/19 Update: Version 0.0 of the Install Guide Uploaded. Please review and private message me if you have suggestions for improvements or additions. Would really like to add sections for 2003 and older installs and any other variations seen. Also, any suggestions for App are appreciated.
That is awesome. I'm definitely getting this. My friend can install it so yeah, no-brainer. Have there been any changes to the unit to accommodate 2003?
Has anyone figured out how to fix the (4) four lower button not working?
Yes, I had the same issue. Turns out there was one cable that wasn’t plugged in. Fixed it as soon as I found that with the help of Phoenix tech support. I believe the plug was grey and had maybe 4-6 wires coming out it and it plugged into the lower center of the bank of connection on the back of the unit.
When you had the issue with these buttons. where you able to control them on the screen? (prior to fixing the issue)
Mine work on the screen... Just wondering if it matters.
I'll take a look at it tomorrow. Thanks!
