Got the radiator installed today thank in great part to (Dan2722) I owe you bro!
So my notes to pass along to someone going with this CSF Radiator:
1.) The transmission cooling lines you need to remove the threaded connectors. That was easy, just loosen the stock clamps and pull the connectors off of the hose then slide the hoses onto the radiator and put the clamps back in place.
2.) The bottom coolant hose is a B!aT@h especially if you are putting a new one on. I found that some silicone grease that I was draining out of my new blue hub fan coated to the inside of the hose and a small flat head screwdriver helped get the hose over the lip.
3.) The final issue was the drain plug on this new radiator. It is black instead of white making it hard to see but it also seems further back so much harder to get two fingers onto it to loosen it. It actually took one of us from the top and one from the bottom to each push on one end of the plug tab to get it loose enough to drain after the flush.
Anyway I hope this radiator will treat me well over the next 10 or so years and next is to add a pusher fan that I can flip on with a switch while on steep climbs or in traffic during the summer.
