Builds Ikarus' HDJ81 Aussie-Style Build (8 Viewers)
Continued disassembling the interior. Pulled the steering wheel, instrument cluster and steering column:
I was glad to see that the captured nut for the top of the clutch pedal is already there, as well as a pre-cut section of the firewall insulation for the clutch mount.
Just need to get in there with a dremel and remove that stud to the top right of the clutch MC hole.
Dashboard out. I swear I had 2x the amount of screws and bolts to remove than the FSM's instructions.
Pulled off the foam/cracked section. Need to figure out how I'm going to reupholster the dashboard and fix the cracks.
Built the clutch pedal tonight. The pedal isn't covered in any FSM I could find so I had to go off the EPC diagram, and I kept a spare clutch pedal assembled to use as a reference.
The pedal and bucket are NLA but all the other parts are available new:
Here's a few photos mid-assembly:
I used Toyota body grease on the moving parts based on the places I saw with grease on the assembled pedal.
One thing to note is there are non-cruise and cruise control clutch pedals. The old pedal on the left is from an earlier 80 with no cruise control. The pedal stop adjustment is a bolt on the left side of the bucket. This bolt is smaller in diameter than the cruise control cancel switch.
The pedal I built is from a later 80 and uses a clutch switch (88280-14030) as the pedal stop.
I need to dig into the EWD and double check but I think I found the cruise control cancel switch connector taped up here behind the instrument cluster:
Local junkyard had a '91 so I grabbed the AC hard lines, drier bracket and pressure switch to relocate my AC drier to the battery box.
The 80/79 hoods look cool, but I thought top mount intercoolers perform worse, love the look.
Id just be afraid of a performance hit.
Yeah mainly the look in this case. Though if the performance hit wasn't too bad it would be nice to simplify the engine bay with a top mount and get rid of all the PDI pipes.
I'm tr
I like the PHAT option with OEM parts. Relatively expensive, would like use case from someone for QC and peace of mind.
I think a quality hood with genuine components won’t be cheaper than a couple of G’s from across the pond. BUT, I suppose you never know. @efjayatee, time to step up and take one for the team! :flipoff2:
Their communication is non existent. Took 2 weeks to get a reply for the shipping cost. I've ask to formally quote/invoice me 2 weeks ago aswell.
I'm tr
Not a bad price but that would make me hesitant to deal with them
