If it looks like this I'd......
....and your spring took the beating...
if your steering is kinda jerky you might want to check this
If you're flywheel looks like this, you should probably replace it:
And on the previous rig.....the windshield glass is good, and you could tear down & media blast the axles, and they would be good as new....:)
problems
If you find this underneath, and main bearings that look like this and you find something like this in your pan, well, You know...
PO Craftsmanship
If the previous owners of your LC had craftsmanship like these you should seriously think about doing something about it...
If it looks like this.
Then Autocad doesn't work for getting the perfect length of your new custom springs for a 4" lift and 45 degree shackle angle........ :mad:
If you are backing up and turn the wheels in 4 lo you might hear a BANG!!!!! You might find this......
This is not the appropriate method for correcting the shackle angle.
if these guys try to get into your cruiser(or cooler)...........................you may want to lock the door.
If your chromoly axles look like this - you might want to ....
If it looks like this.... you might not need that new cam...
If your tow hook looks like its giving you the finger...then you might want to get a better one.
unrated tow hook that was on my cruiser when I got it:rolleyes:
