Or proper way meaning with the firewall down?Ok. Try it the proper way next time and if it fails on an individual file, post up which one (like a .inf file, not a .cab file or similar)
Does anyone know which VB build works on MacOS Catalina? I've tried downloading the most recent (I think 6.0.24 or something like that) but I keep getting an Installation Failed notice when I try and install it.
I will give that a shot. Thanks!Yeah I just had this problem. What worked for me was to allow downloads from outside sources. Should be:
System Preferences -> Security & Privacy -> Allow apps downloaded from outside sources
So Version 14 and above cannot modify values on the 460? Sorry I don't know what IIRC means.Customization is gone from V14+ IIRC on the 460
did they ever respond to your question?I submitted a question to OBDInnovations last night so we shall see if I get a response.
Basics was "What is difference between v1.4.x firmware and v2.x?" and "Will a cable that is 1.4.x work with newer version 13.xx software?"
I asked a question via email & Facebook back in August and haven’t gotten any respond either. They’ve had very poor reviews in the past year or two. I don’t recommend buying anything from themNegative... never got a response from them.
Thanks! I'm using Version 15.3.026 and i can't see the TPMS option. The new (hacked)version came with the OBD cable. Pisses me off because i bought the cable so i can work on the TPMS sensors and it doesn't seem like i can do what i intendedSorry... If I Remember Correctly version that utility menu went away was on v14 and later.
Older versions here
Bump. Just checking if anyone knows a good option for another reader? I'm hoping to not buy an incompatible oneHey the cord for that techstream link is sold out...: Amazon product ASIN B06XGB714M
Any ideas as to another option that will work well? I don't want to buy the wrong one.
Pretty much any of the ones you find on eBay or Amazon will work just fine. You can go a little more expensive if you want to with someone like OBDInnovations, but that is not absolutely necessary.Bump. Just checking if anyone knows a good option for another reader? I'm hoping to not buy an incompatible one
