PabloCruise
Post a video with the noise.
Vehicle is at dealer and unfortunately I couldn't film it because I needed to be driving to make it happen . Almost always happens when pulling into parking spot or at full wheel lock to the left.Post a video with the noise.
Thanks. I'll have them check it all over. I did use the 555 lowers and they have held up nicely .Do check torque's including wheel lugs, rack, TRE, links & bushings and shocks. Also check ball joints, including the shafts is firmly seated.
When ball joint replace (non OEM) the 555 are used very often. It's important the boots be removed to press them in. All to often, the boots are not removed. We then see them fail! If ball joint not torqued to spec. The shaft may not have fully have seated.
I believe those adjusters are as far out as possible.
It was suggested that we tighten them down enough so it doesn't contact anymore but Toyota warned me the rack might over extend . Is that possible ? When I first bought that truck it didn't even have those stoppers installed , I put them in and just kept the at their max adjustment ..
I've never had an issue until the steering rack swap. They assure me the rack is centered and everything was torqued down properly, which I agree now that I've seen the issue.
I'm not sure what to do. any ideas ? If we just snug that stopper down enough to not contact could that stress the rack out for any reason ?
They told me the old rack ( which was a reman that they installed ) wasn't centered and didn't turn as far . I get how s*** works down there but since I didn't install i'm not super knowledgeable with centering the rack. Didn't even think that was a thing .It puzzles me that you didn't have that noise before the new rack job. There is a cure if it is really a stopper noise but I don't know if this is the size you need.
Spindle Steering Stop Cap | Marlin Crawler, Inc.
Genuine Toyota Spindle Steering Stop Cap for 1986-1995 Independent Front Torsion Bar Suspensions. These factory plastic caps go over your steering limit-stop bolts and insulate them from th...www.marlincrawler.com
Appreciated .If greasing the knuckle-stops, changes the sound. Then likely is cause of new sound.
The 555 do change the relationship of knuckle to LCA just a tad. I've never looked at stops hit point, after 555 install. But that "may" have contributed. That and a fresh alignment after rack.
100 series at stock height, stops usually do not bind. But lifted, even by cranking on T-bars past spec. The stops may hit high, and sometimes bind. If sound is only when turning to stop (fully to lock) in one direction. Then you may not by properly cross leveled and or aligned.
Setting higher caster, will also bind knuckle-stops. I see this with SPC UCA & UBJ, which kicks up caster. A test of caster set high, like above 3 degrees. I find is; as I drive down the HWY it tracks (no wondering) very nicely. But as I go to change lanes, it yanks off center (straight) abruptly.
Many installing over-sized tires. Adjust knuckle stops out as far as they can, to reduce tire rub on inner fender. I've seen a few knuckle stops missing, from adjusting out to far and or not locking them down. Out to far will not hurt rack & pinion. I'll also say; I've not seen damage, from missing stops. But understand; I'm not saying removing will not damage rack. Personally I'd not remove or turn in, passed FSM spec.
BTW: Rack & pinion before mounting bolts torqued down. Move a few MM left or right of center. I always try to center best I can, before torquing.
Kalispell Toyota .@Mike NXP Where did you get the work done?
Agreed, I think the bushing or torque on those control arm mounting bolts can very well be a factor.@Mike NXP I had that sound before and after I did a lot of front end parts, including the steering rack. So I don’t think there’s anything wrong with the new rack.
Unfortunately, I still have the sound. After reading through a couple other front end pop threads, I’ve been thinking it’s the Lower Control Arm bushing No 2. For you, it’s possible your new rack is all nice and tight, plus a nice new alignment, that bushing is now getting more torsion?
The shop I bring my cruiser to made it seem like that sound must be some bushing but they couldn’t narrow it down without doing a lot of work.
Speciality alignment shop just told me to slap some grease on it. Are these people nuts ? This vehicle has driven 230k miles without ever making that noise.Agreed, I think the bushing or torque on those control arm mounting bolts can very well be a factor.
In my case , I can see the wear marks on the stopper and can see where it is contacting.
Now to figure out how to solve it. My guess is rack not centered or torsion bar cross level not set right .
Understood, thanks . I'm still puzzled why it's contacting . Something's not right .The intent of the limiters (stoppers) is to limit how far the steering assembly is able to turn. At full lock with the limiters either removed or fulling screwed in, you will get a straining pump noise. I believe the FSM has a procedure for adjusting the limiters out to a point where at full lock the straining noise is not occurring. While it is possible that these could cause a noise when you are at full lock, they should not be engaged at any other time.
I mean if you are at full lock and it is contacting it sounds like it is operating as it should? Maybe I am missing the original issue.
