How to LS Swap a FJ60 or FJ62. Quick and dirty guide for regular folks wanting to do an engine swap in their driveway.
Re-read what I wrote.. I don't think you realize MOST of the available harnesses on the market do not have the position switch wiring integrated. I have only seen that on the Painless (like you have) and Current Performance brand harnesses. I have not seen anyone else on this forum use a harness from either of these companies other then you.
trying not to pimp my stuff too much but for those that have PSI, BP, etc harnesses.. this is the easy button
Most of them assume people arent including the NSS switch in the starting circuit it seems. Which idk why someone wouldnt. But they do offer it as an add on
It's a pretty simple reason, they aren't part of the engine/transmission wiring on the original GM application. Just body-side/BCM. Just like how Toyota setup the FJ62.
Added the post to the table of contents. I also added the GM wiring diagrams for the Neutral Safety Switch and starter relay, as well as the reverse light circuit out of the PNP switch to the post from the wiring mistake. Just in case your harness doesnt come with the purple or yellow wires for the NSS
@dbbowen you have left a lasting legacy for all of us with your generosity on information not many are willing to share. We are all learning, mistakes included. It takes special humility to share mistakes. Thank you!
Haha thanks man! I feel like the mistakes add a little bit of humor and learning moments to the overall thread
Another post to add to the thread that i wish i knew 2 years ago...
If you are planning on using a 4l60e transmission in your LS Swap into a 60.... do not use the split transfercase or advance adapter at all. The split case whines no matter what you do to it. New bearings? Whine. new adapter bearing? Whine. Brand new transfer case assembly? Whine. Literally nothing you do will stop it from whining. The whining isnt too bad and a lot of people cant even hear it over mud terrain tires, or sound deadening, or the radio.
The solution.
@TRAIL TAILOR offered this solutions months ago to me and i totally forgot to put it on here and didnt really fully know how it worked until @cruiseroutfit explained it in detail.
Use a HF2A Transfer Case assembly from an 80 series. Buy a Spool for it and wire in a center diff lock switch for the CDL actuator on the Transfer case.
The HF2A doesnt whine when behind an adapter, you can put drop in low range gears into it without machining the case body, and youll use an adapter from advance adapters for it that doesnt suck like the garbage they make for the split case.
Heres how it works.
Links:
Brand new HF2A Tcase
Spool for HF2A case
Tcase Adapter
For what its worth, The split case and 4l60 havent given me any issues outside of it whining. That being said, if i knew this info when i did my swap i would have gone this route instead of using the split case. The HF2A case comes with a bigger cost, but i think its worth it to have a quiet powertrain
So this thread got me into swapping an LS/6l80 into my FJ62 using 80 sires diff case
Just dropped the drive train using well sorted engine mount ( highly recommended) and i have some questions and concerns
1. the driveshaft angle is 3 degrees off and the diff is already almost touching the floor ( do i need to cut and raise ?)
2. what are the cons if i keep the awd
3. anyone with linkage photos ?
Thanks
1 - diff ? Touching floor? Do you mean transfer case?
2- more wear and tear on moving parts in the front axle if you still have the 62 axle you have lock in lock out hubs
3- I doubt anyone has pictures of this.
Atleast with the 60 case, you can match the case flange angle to the diff angle and keep it tucked up tight. Mine has more ground clearance than stock and no driveline vibrations.
Mine is ~3deg down, within 0.5deg of the axle flange
Thanks
Do you have photos of said angles also what transmission crossmember are you using?
Thanks
Ideally you want the motor and trans to be at a 2* or so angle from front to back of the truck. If thats what you mean by driveshaft angle. My truck is at 3* and my tcase is about 1/4 inch from the floor. You can either measure this by putting an angle finder on the trans output flange or if you take the intake manifold off and set the angle finder in the valley on top of the engine.
I personally dont like the full time 4wd and is a big reason i dont drive an 80 series. Its a lot of wear and tear, you got to worry about Ujoint angles in the front and nailing them perfectly if you dont want any driveline vibrations, and if you ever have any front axle issues you cant easily just put it in 2wd. If you did want to keep the full time 4wd youd just need to install drive plates from an 80 series or just have your lock out hubs locked 24/7. The 80 transfer case has a diff in it so unless its locked, if your hubs are unlocked it will just try and spin the front axle and you wont go anywhere.
If you are talking about your rear diff angle being off, you can just shim your rear axle with shim plates from cruiser outfitters or valley hybrids to match up the diff flange to your tcase output flange for driveshaft vibrations
that was really helpful
back to work then
will look into the axle shims
thanks again
Thinking of using serrated flanged TEQ type bolts in place of AA allen bolts. Anyone done this? Have specs?
Next is fuel. There are a ton of ways to skin this cat, and the setup is different for gen3 vs gen 4. Gen 3 motors use a fuel pressure regulator that is located on the fuel rail itself. Gen 4 uses an external fuel pressure regulator. Ill do my best to talk about both here.
So the absolute greatest way to do this is to call @orangefj45 or @wardharris and get a long range tank for a fj62, and then put a deatschwerks unversal in tank fuel pump in there. Then run your supply line with a fuel filter using -6 hose or bend you some stainless tubing to take the place of the stock fuel tubing.
In the real world, that whole setup is $$$$ so this is just a way to do it cheaper and simpler. This is what i did in the meantime, but am planning on eventually going with the long range tank with in tank fuel pump. The in tank fuel pump is much quieter and more reliable, but not totally necessary for your swap.
So earlier you removed your supply fuel line when you had the engine out of the truck. Go ahead and remove the brackets for your brake lines and your return line. Save the bolts and everything. Youll notice on the frame where it bends towards the rear there is a lot of empty non threaded holes. You can use rivnuts on these to secure your in line fuel pump. Move your lines around and try to make some room for your fuel pump to be mounted, its pretty obvious where things will want to live. If you mount it here it will be below your tank and wont run dry. I personally like the deatschwerks products over the warlboro stuff, but you can choose to use whatever. The Warlboro stuff has complaints about pressure falling off at higher RPM and the DW pump doesnt. If you have $$$ to spend aeromotive is probably the best fuel pump you can buy. For a stock LS, the DW250IL is plenty for a fuel pump. Its a little noisier but will give you a bit better performance.
Speaking of fuel pumps, you will want to use some rubber isolation on the pump bracket to eliminate some unwanted noise. From your rivnuts you can use these rubber isotors:
amazon link
Those are m6 so obviously use m6 rivnuts. they will isolate the vibration of the fuel pump bracket from your frame rail. Then use the supplied rubber that came with the fuel pump bracket to isolate the fuel pump from the bracket. I also added to my bracket with rubber mastic tape to increase sound dampening. You can mount the fuel filter to the frame rail closer to the front of the truck using an existing threaded hole and also a rivnut on a blank hole. Once this fuel pump bracket and the fuel pump is in place and the fuel filter is in place, you have a base of where to run your fuel lines. You want to come out of your gas tank with regular fuel injection rubber hose, into a pre filter, then into the fuel pump with normal fuel injection hose. From the fuel pump forward is where the high pressure AN hose begins.
You will build these hoses the exact same way you built the trans hoses in the posts above.
For a Gen 3 motor using the stock fuel regulator on the fuel rail you will use a regular high pressure fuel filter after the fuel pump. Then run -6 line all the way up to an adapter on the supply line on the stock fuel rail on the motor.
For the return, use the GM oem fuel return line that was on the motor. You will need to keep the GM return line but cut the metal hose 3 inches from the flex hose. This should give you a quick connect, the black flexible hose, and 3 inches of metal hose to use. With the GM quick connect attached to the fuel rail, attach a rubber fuel injection hose to the metal part of the hose you cut from the oem fuel line on the opposite end, and attach the other end of this rubber line to the stock toyota fuel return hard line that runs along the frame and back into your tank. You can use AN hose and fittings for this if youd like, but this is very low pressure and it is not needed. Worm clamps, or even better breeze clamps are fine for all of the normal rubber fuel injection hose as its low pressure. there is a special tool to remove the GM OEM fuel lines from the fuel rail, they sell them at HF or amazon. Definitley get a set, theyre cheap
Here is a diagram of the fuel supply line i drew out to help visualize it. All of these fittings are -6 in size and if you want to upgrade i would suggest vibrant. These fittings are a place where you can splurge some. Especially on the adapter for the fuel rail and the fitting off the adapter.
Gen 4 will use a Fuel filter with a fuel pressure regulator built in and will have a return back to the tank from the filter. The Fuel pressure regulator and filter will look like this. The main difference in the line will be that your fuel rail will not have a return. You will need to remove your stock return line, and make a new return line off of this filter back to your tank. This will go in the same spot as the fuel filter for the Gen 3 diagram above.
Quote @Megadoomer " in 2003 GM has a Late 03 GEN3 motor that is returnless fuel and DBW without AFM or DOD. "
Here are some pictures from my setup.
Fuel rail. Notice the gen 3 fuel filter regulator on the fuel rail. Also the lower return line is the stock fuel hose modified and the upper is a -6 line with 2 AN fittings.
Once your hose is built and your filter and pump are mounted you can tighten all of your AN fittings, and reuse the threaded holes in the frame to secure the fuel line with Adel clamps to the frame. You might have to share a bolt with some brake line for some of the brackets. There are plenty of threaded holes under there.
Also, while you are in here you can go ahead and knock out your vacuum hose that will attach to the brake booster. You can use the stock vacuum line fitting that is located on the back of the intake and use some of the old transmission hard line to shove into the plastic vacuum line fitting for the GM intake. I put a bend in the hard line and filed it down some and epoxied it into the plastic. Then you can use a Molded 90* 1969 camaro PCV hose to connect to your brake booster for a clean look. PN: EGP-1792. The trans line and the vacuum port on the brake booster are both the same size so you can just use this hose alone. You can see it in the photo with the fuel lines:
If you would prefer not to do this vacuum hose for your factory brakes, this is a good time to swap over to Hydroboost brakes. You will need the PS Pump from a 6.0 truck, it will bolt into place. Then (if keeping stock 60 brake calipers) get a smaller bore Hydroboost master. 1 inch would be ideal if you can find it. If you go larger you will need larger brake calipers. I am still going back and forth on swapping to hydroboost personally.
Once you are done with this, check all your AN fittings again to be sure they are tight. This is the one dangerous part of the swap. If you overtighten a fitting or under tighten it at the fuel rail it will drip onto your exhaust. You really want to get this stuff right the first time and double check it after start up and check for smells or leaks. You should never smell any fuel in here.
As far as the Charcoal canister is concerned, I just removed mine completely. I attached normal fuel injection hose from the metal line along the frame rail by the passenger side firewall and ran it up behind my wiper washer bottle and put a 1 way breather valve on it. I have had no issues so far running it this way, and my buddies with LS Swapped 240s havent had any issues doing this either. You could use a fancy ARB breather if you wanted but the cheap dorman ones from Oreiley work just fine. I did have to shim my washer bottle out some from the fender with some washers so it would not kink the hose. You can also see my Fuel return line in this photo as well, both of these hoses are secured to the firewall with adel clamps using existing threaded holes. Ironically, before i removed my charcoal canister, i could never fill my 60 up past 16 gallons when completely empty. I always thought that they had 16 gallon tanks, but after doing this i can fill it up past 20 gallons. Im thinking something was wrong with my charcoal canister or something. I also had a lot of blowback when i opened the gas cap and the gas pump would always overfill out of the hole. Since doing this there is not really any blowback of fumes and the pump doesnt spew gas out of the filler hole anymore. It is hard to see from the photo, but there is DEI heat wrap wrapped around both the return rubber hose and the vent rubber hose down there under that little bracket. I have that running into another heat wrap covering the fuel hoses and wiring near the exhaust. That little section of frame rail gets pretty busy, but with some heat protection youll be all good.
first off great post and notes....will be helpful to many. I'm wondering about a few things and your experience. You said you removed the evap stuff which is just for clarity...did you remove that hard line on the firewall that is or one of the fuel tank vents (the hose off of that use to feed the OEM charcoal can) from my memory? On your vent you are using now in the above pic coming out there near the washer bottle, do you recall what specific check/valve / vent you used ? And did you just tap into the former hose that use to run up on the firewall for you vent setup? Also last question.. have you been on any steep descents offroad with a full fuel tank....and no issue with liquid fuel coming out the vent ?
I know this is an older thread but anyway ....though I would ask a few questions. I've been looking around to do something better on my end for the fuel tank vent setup.
Man. Ive been meaning to update this thread. My solution for the vent is wrong and only to be used temporarily. It vents gas fumes out of that and isnt a good permanent solution. I am collecting the parts to reinstall a charcoal canister and run it to the purge solenoid on the GM intake and run it from the PCM. That hose in the pic with the one way valve on the end is connected to the hard line that runs under the truck for the vent. I have had liquid fuel come out of that vent, especially after i did the fuel tank recall. I have since relocated it up in front of where my headlights are for a temporary solution.
This is the charcoal canister i am planning on using. I am going to mount it back near my fuel tank. There is a soft line that goes between the fuel tank and the hard line that runs up the side of the frame to the engine bay. Im going to run the soft line from the fuel tank to the inlet of this charcoal canister, then run the outlet to the hard line. Then in the engine bay run a hose from the hard line to the purge solenoid on my intake. The large outlet is the vent to fresh air
In the tune for LS Swaps you can never really turn off the operation for the purge solenoid. You just disable the MIL Light for it. So theoretically if you run the correct wires to the PCM it should work just like factory.
Ive been busy with other projects but this one is on the to do list for the next few months. I just really need fittings and a purge solenoid and this charcoal canister. I dont want to mount one in the engine bay because the can style ones are ugly and take up a bunch of space. Once I do the charcoal canister ill update this thread with the info on that post you quoted above. I live near radium engineering and was going to use them for the fittings and get their thoughts on the GM fuel quick connects to low pressure hose fittings
Curious to see how this works out, I run a rollover check valve on mine in the inner fender behind the antenna. Never had fume issues but it didn’t feel right
I only get liquid fuel coming out of mine with a super full tank on a super hot day or anything above a half tank in moab in July haha
If I'm not mistaken the charcoal canister has it own valve if that you wanna call it with a little filter with wiring to control it along with the one on the intake and was mounted in the rear over the rear axle. know for a fact on gmc dinalie how ever it's spelled I've owned one if I ever do a legal complaint swap using the gm factory components is the way I will go much more work making gas cap sensor not go off rear evap sensor front evap sensor along with fuel tank pressure sensors working.
I've been in the same boat to some degree. I have a vent to atmosphere....but I don't like it, in my case its a simple hose running from the hard line on the firewall off to the driver side wheel-well. (I don't like that but its what it is and I"m not saying its correct or anything beyond that). My engine is a 5.7 vortec. I've been looking around at the various valves etc, roll-over valves, one-way check valves, discriminator valves etc. In ever-day driving I don't have issues (road use) but at extreme angle descent with fully loaded fuel tank I had liquid fuel come out the vent hose I'm referring to. I've really been thinking about using one of the one-way check valves to put in line on the vent hose I'm referring to (before the high point, so if there was fuel in the line it could drain back to the tank), and where this valve is supposed to allow vapor to vent but not allow liquid to pass (how well that works I don't know). YES liquid fuel coming out is dangerous and stupid etc, yes if the truck flipped or had some off-angle accident there could be a problem with liquid fuel escape. A thought I have had..(which may be flawed but its a thought). What if one came in and put a one-way valve in line on the hose that is the fuel tank vent (the same hose) that feeds the hard line on the firewall , avoiding situations to trap fuel where it can't drain back. This is my mind would potentially control liquid escape to some degree and then you then would be in vapor control. So then run a hose from the hard line port on the firewall down to charcoal canister to its input port, on the vent side of the cannister run a hose as high as you can and put a roll-over valve there. and or tie in line from charcoal cannister back to intake. I'm not sure how many ports some of those cannisters have. This assuems OEM Evap is gone (which in my case it is) this assumes that there does not exist full on evap system from whatever engine combination is being used, and this assumes you are trying to setup something that is safe and functional and controls liquid fuel for sure....and then fuel vapor to the extent possible also in safe manner. I don't drive my 60 that often and it sits around a bit and I get caught up on different projects and other things... But I too need to solve this in a safe manner. There are some interesting valves and so forth, but I would have to admint I dont fully understand a proper setup...or I would have already done that. There are some other threads where people are using the "coffee can" type charocal cannister thats a GM product or GM clone. But Im guessing it does not really matter which one you use as to cannister or evap box. Speaking of myself....yes its dumb to have a situaiton of liquid fuel being able to escape the fuel tank vent hose, and yes its dumb to not deal with vapor properly. Dumb = not safe. In my case I've only been aware of liquid fuel coming out the vent hose...on a cracy steep descent trail I was on with a group out in Moab where it was a place I normally would not have done...but it was the only option and stay with the group...and in the cab I though it was close to pitching forward or flipping forward (yea) then I get half way in the steepest part, and I smell gas...and at first I thought minor thing..then I was able to stop mid way and then say a stream of gas about like a pencil in diameter coming out the wheel-well. Could have been a fire coould have been really bad. I've been lazy and so forth...but its something to solve and I too am looking to be safe. At this extreme angle you have the fuel tank up high...(full tank) and then everything else is a low point at least to some degree. and so what would happen if the the truck flipped or whatever else...yea might be a bad day.. sounds like your approach is viable as to the changes and makes sense. I dont' want to re-create the full blown GM evap thing but I do want a soltion that is safe and functional (my view) but I would use GM components where possible. one smart move might be to replacate some things like some of the modern cars etc have...where there are sensors/valves on teh fuel tank itself...but anyway thats a big deal. I've not understood really that at the end of the day will one of these check valves or other valve...really alllow vapor to pass and not fuel.
