Your engine bay looks awesome. Nice n clean.
Large manufacturers have engineering standards and specifications for everything. This includes the torque for worm drive band type hose clamps with new hose.
CLAMP WIDTH (mm).........INITIAL ASSEMBLY TORQUE (N-m)..........REASSEMBLY OR RE-TIGHTEN TORQUE (N-m)
15.9...........................................7.5....................................................4.5
13.5...........................................4.5....................................................3.0
7.9.............................................0.9....................................................0.7
Conversion: 1 N-m = 0.737 LB-FT = 8.85 LB-IN
Sidebar issue re: hose quality - My first Toyota was a 1979 FJ40 which I bought new. As a rubber technologist I was extremely impressed by the quality and long service life of the factory hoses, seals, gaskets and belts. I was used to American vehicles and what seemed to be constant low service hour leaks and failures of these components.
Thank you for that info. I was trying to figure a way to ask the question you answered above....This helps take human error out of tightening the worm drive clamps too much. I take it, these numbers can be somewhat applied to the screw drive/wire clamps?
That's the source of his problem. In most engine compartments, you won't notice a drip here or there.Your engine bay looks awesome. Nice n clean.
The main question is what is Rick going to use? If it is good for Rick it is good for me
Jeff
Large clamps for the lower radiator hose to water pump & connector pipe (3); NORMA ABA Safe W4 - 42056
Medium large clamps for the lower radiator hose connection & upper radiator hose connection (3); NORMA ABA Safe W4 - 42050
Medium clamps for the By-Pass hose (2); ABA 316 Stainless Steel - #10
Small clamps for the 5/8" heater hose line (8); Toyota constant tension band clamp #90467-21010
Would you, perchance, have your source for purchasing these clamps (I can get the Toyota clamps locally but is there a single source for the others?)
If I was to do this again. I'd just purchase all 316 SS Solid Band hose clamps from Fisheries Supply and use Indian Head Shellac on all hoses.
That would be a YES! The supply line thru my fire wall is bent pretty good. So I knew I had to use some sort of sealant to help seal the hose to metal line connection.
I did a test with four different gasket makers using the rubber hose and a metal pipe connection. The four gasket makers I used were; Toyota FIPG, Permatex Ultra Black, Permatex Water Pump & Thermostat, and the Indian Head Shellac. After making the test pieces, I let them sit for 48 hours. What I did was put the metal pipe in a vise and twist the rubber hose till it broke loose. The FIPG was worthless in this application, the Permatex Water pump did alright, the Ultra Black did OK, but the Indian Head Shellac won hands down. With the Indian Head, I had to be cut the rubber hose off the metal pipe.
Well I get another shot at my Warthog. Just found a crack in the block. I’ll order some.
Is "gluing" the hose to the pipe (Indian Head Shellac) a good thing? If so why not some other sort of glue? Superglue for example? Gorilla glue... etc etc?
Gluing precludes removal and reuse of the hose (for example to replace another component or to get the hose out of the way for some other access... not sure I'd go that route.
