My impression is shims. I put in med OME and 285/75R17 MT's and even that mild lift req'd
2.5 or 4 deg shims. I don't recall which we went with.
Yes, this. https://forum.ih8mud.com/threads/another-hj61-from-finland-this-time.803514/Thanks, I'll keep it up!
You got a 61? Thread?
Not had an alignment... Only thing to check is toe, and they would charge $170 for a check.
Toe is good, camber can only come from something being bent, so I checked the degree with a gauge on the disc, relative to the horizontal axis, and both sides had the same degree, I think 1.8.
I bought 4deg caster shims from George, but have not installed them.
Didn't have them on the previous 60 with the same setup.
Can I measure the degree on the pinion flange, and compare it to others?
I tried setting the toe in to zero, and worked it in a mm at a time, while driving, it didn't matter much, now I'll set it back to almost zero.
Have checked bearings on passenger side now, and put on new rotor while I was in there.
Next is left side.
And triple check that the tre's adjustment is good.
And I'm gonna try to borrow another set of rubber, to see if wheels/tire play a role...
I'm tired of wandering!
Really like the grey touch to those mirrors well done sir!!I was playing with plastidip on the mirrors i got from @reevesci and found my colour. dark gun metal grey.
my last plastidip experiment was not sucsessfull, and it did not stick to steel or plastic.
Now, in good temperature and several thin layers, a few minutes between the three layers, it turned out great!
Swapping out the mirrorsI'll try it on the bad wheels, and misc odds and ends to see how it holds up in various conditions.
I'll might do a hood dip, to minimize sun glare. I like that it's not permanent, but i dislike that it's not 'permanent'
2nd coat
3rd coat dry
Objects may appear closer than they really are.
After tightening the drag link ends, things got better!! I guess now the toe has to be re-dialed
My vote is Toe (too) now that the drag links got tightened up.
Also... I never installed shims under the springs in the front. My bump stops are over 4" away from the axle housing. Steering has never wandered. Ever. IMO, and in my experience, shims are not needed for normal HD springs. Or to put it another way... If I haven't needed shims for 27 years with my current tall springs, they certainly won't be needed for the next 27.
I do have several sets of spacers and pto gears. I might try it with an old stick weld. Maybe I can put the gears and spacer on another h42 with good splines at the output shaft and do the welding there.
I'd grind a V between the gears and spacer, heat them up good and weld half an inch at a time.
Hopefully it won't warp much if I have it on good splines and then let it cool slowly.
I guess a McNamara gear is splined all the way?
If I twist the input gear so that it engages the twisted splines, I would have a larger contact area, but it would have to be welded on the axle, and I wouldn't be able to remove it later. Ugh...
Looking at the parts diagrams, the H55 has a different output shaft than the H41 and H42.
