- Thread starter
- #101
Man, none of this computes with me. The fact that is stops in both directions has me at a loss. I previously thought foreign object in a cylinder - that would cause a hard stop in one direction at contact, and would also have to be something odd shaped to get through a valve and yet be large enough to stop a piston’s upward travel. Then you’d need two of them in separate cylinders to stop motion in the opposite direction. Not impossible, but astronomically unlikely?
Thought about something coming loose in the timing gear housing, but also would only likely cause a stop in a one direction. As well as something like a hex nut caught on the back side of a cam lobe. Would stop in one direction, but ought to be rollable in the opposite. And in any of these cases, while running and driving would have produced an unmistakable “bang” or “pop”.
Wish I could be more help, but I’m sitting by holding the popcorn bowl, awaiting to see what this boils down to.
Lol. seems my journey into pig land is clearly going the path less traveled. Between my throw out bearing mess with the clutch last year, my brake job disaster that was fixed after a month only with a 2nd new booster (City Racer swears the other one is fine and I'm stupid
Squeal like a pig, boy!!! Reeeeeeeet!!! Reeieieitit!
I agree about something in the cylinder seeming like it would back out by turning the other way and thought the same thing that both cylinders would have to have something in them, but considering the flywheel goes only 2 teeth, I don't think there's enough travel for both of them to have something in them and hit. I'm not up on gear ratio, but two teeth on the fly wheel isn't very much of the full engine's revolution. Looking at pics of the engine in the manual today my thought was timing gear jammed up with a nut or cracked maybe and something jammed in there?. I can see the cam from underneath and it looks good from what i can see anyway. Not broken. Is getting at those timing gears easy or I probably have to pull the radiator, right?
That thought brought me to a search where I found this thread, that's eerily familiar. Dies out, ground and starter stuff, realizes the engine is locked but moves a little bit..starts going towards cam and timing gears and......the thread ends like the Sopranos! Come on!!!!!!!!!!!!!!
Bizarre Issue with a '76 FJ40 - Help is appreciated!
