Hey all, hoping I could get some advice here on a chronic issue I have had on my 99 UZJ100.
Vehicle Stats:
Purchased: April 2014 - ih8mud listing
Current Mileage: 266,682
I have meticulously kept up maintenance on the vehicle and only now am I having trouble with diagnosis and solving the root issue of my truck's cylinder misfires.
Please see the service history below for reference
I originally had replaced all spark plugs and #7 coil pack in 2017. This was the first time having to replace plugs and coil packs as the truck's owner. This lasted for a few years until I decided to do preventative replacement on all 8 cylinders. It seems as though these fixes last for a summer, but as soon as winter in Colorado comes, the issue comes back. In fact, it seems to really be triggered by snow/cold weather.
After a full replacement, the plugs/coils lasted for a year, then like clockwork, started misfiring again. Cylinder 7 on 12/01/2021 was promptly fixed.
Then Cylinder 1 and Cylinder 2 only a month later. I had shrugged this off as either poor work done by the mechanic shop, or poor quality parts (ECH Ignition Coil - IC336).
Fast forward another month, and Cylinder 1, Cylinder 2 and Cylinder 7 begin to misfire AGAIN. At this point I started to worry about an oil leak or a head gasket issue so I took the truck to a Toyota specialist who only focuses on 4x4 Toyotas. I had them run a compression test and the truck came back with flying colors. The mechanics had noticed water sighting poor sealant by the previous mechanic. All 8 plugs (Denso 673-1303) and coil packs were replaced and the truck ran fine throughout the summer.
Once again on a snowy day in January, the truck has begun to misfire. P0300 (Multiple misfires detected), P0301 (Cylinder 1 misfire), P0302 (Cylinder 2 misfire), and P0307 (Cylinder 7 misfire).
There is certainly a pattern here, why would it only be those 3 cylinders constantly? I will certainly keep replacing plugs/coils/etc, although I shouldn't have to do it 3 times in 3 months as I am having to do now. I am having tough time figuring out the root of the problem.
The next steps are to run the truck through a series of tests that are seemingly simple but expensive at a mechanic. Ex. Water off the windshield.
Will also look again for oil in spark plug wells, look for faulty connector/wires, check for blown fuses etc.
I am at a loss, so any help would be MUCH APPRECIATED!
Misfire Related Service History:
P.S. There has been an extensive amount of work done to the vehicle. Above is simply related to the issue.
Vehicle Stats:
