I'd just consider the one. They can last nearly forever so I wouldn't expect any other time-related failures.I did confirm that #3 plug is firing, so that's good news. I did not do a compression test yet as I believe I gave that tool away before I moved last summer. Who knew I'd need it. Looks like I'll be buying a new one.
Interesting if the #3 injector decided to leave the chat at this specific time. I see that these injectors have been rebuilt here, approximately 96k miles ago. Which makes me wonder, do I have this rebuilt or replace with new? All 8 or just this one? I'm scared to investigate the cost of 8 new injectors...
Not likely related to being rebuilt 96K miles ago.Interesting if the #3 injector decided to leave the chat at this specific time. I see that these injectors have been rebuilt here, approximately 96k miles ago. Which makes me wonder,
If buying new, I'd just buy one. OEM injector VVti list today at $252. $164 to $174 wholesale. For next 2 weeks, 25% off wholesale $142.do I have this rebuilt or replace with new? All 8 or just this one? I'm scared to investigate the cost of 8 new injectors...
That is so nice of you. Can I ask, which make & model number? Would you buy them again, or some other?I've got noid lights if you want to borrow them. I also have a few used injectors that I have cleaned. You are welcome to one of them if you want it.
I would for sure check compression, before R&R of any fuel injector (FI). Why:
- Misfire just after T-belt service, where crank was spun while T-belt off. You may have had an "interference" event. If just one valve stem slightly bent. Valve will not seal, and fuel/air mix can not combust since air pressure escapes.
- Both leak down and compression testers. Are often free use, from parts stores.
I feared as much! Believe me when I say, I'm very sorry to here!
So now we know. Cams Timing Marks on the "I" in VVTi. "I" is for interference. Question I still have, is the "T" safe or also interference.
Study and prep for the job. Plan on 4 days minimum. Take your time!
Make sure to study and follow FSM. Very import step, is to lock off cam sprocket with 10mm bolt before pulling cam caps.
All cams, cam caps, spring, bucket shims, valves must return to same spot.
You'll need to reset cam lobe to bucket/valve gaps.
Be very organized and clean.
Good luck.
No, S**t happens! You're the OP, but it's not just about you. Many people will read this thread for years to come. I'm, as TM suggest, speaking in general to the forum.If you’re implying that I rushed through the job (5 days), that I don’t have an FSM (got the complete set) or that it was my first time doing the job (3rd) you would be incorrect on all accounts.
Even though I’ve been working on cars since I was able to hold a flashlight for my dad I am not a professional mechanic so I take things slow and methodically. If this is indeed what I/we think it is, I second guessed myself when checking the timing. I removed the belt and rotated the engine by hand, I did not feel any interference in the slightest, so reinstalled the belt. Apparently I f*cked something up and I own that. Now I have to fix it.
