Good luck @CRZR45 . Been looking for years. Not sure why they stopped making them.
But freeway with 33 inch tires and 4.10 gears its 2000 rpm at 65 mph with a 1F engine
I have 2f h42 toy box split case and 4.56 gears and 37” tires. Speedo is spot on and at 65 I’m at 2800 roughly and that’s confirming with gps.. I don’t know how 2k rpm at 65 is possible without 5th gear and other gear mods.That sounds too good to be true.
33" tires rotates 630 times per mile. Multiple that by 4.11 for the diff it comes to 2589.3 RPM. That's is at 60 MPH. Multiple that by 1.0833 which is roughly 65 MPH and you get just over 2800 RPM. J30/H41/H42 transmissions are one to one in the in top gear. Same with the transfer cases high range Toyota used. Most my FJ40 driving has been in my 68 FJ40 with a F145. It loves 1,100 RPM. Okay up to 1,800 RPM. Cruises at 2,200 RPM but starts to feel like I'm pushing for long periods. But higher really try to stay away from other than short periods like passing.
Do not believe either the SM465 or the Dana 18 have any type of OD? Stock gearing the Dana 18 low range is 2.46:1. Not that much lower than the transfer case in the 1970 FJ40. Biggest gain is in the first gear of the SM465. If you can do 65 MPH @2,000 RPM with that set is great. Just not understanding how.
Advcanced adapters bought the patent, for the warn overdrive for the dana 18, I almost did it but havent yet. You can split gears with it.That sounds too good to be true.
This doesnt answer how you are at 2000 rpm at 65 mph? Or are you numbers just hypothetical?Advcanced adapters bought the patent, for the warn overdrive for the dana 18, I almost did it but havent yet. You can split gears with it.
Look it up in Mythopedia; it’s under fuzzy math!This doesnt answer how you are at 2000 rpm at 65 mph? Or are you numbers just hypothetical?
no I have a tach and I have also tested it with a snap on tach also. I did a 2500 mile road trip in five days in it, ran just fine.This doesnt answer how you are at 2000 rpm at 65 mph? Or are you numbers just hypothetical?
Are there alot of problems MC toyboxes?because they didn't sell that many, had a ton of problems, and not that many people are really wheeling Cruisers any more, plus now there are good options for transfer case gearing that didn't exist back then.
If you absolutely have to have a crawl box NWF has their Blackbox ready to go
Blackbox Landcruiser
Current BlackBox Build Time is 12 Weeks BlackBox-C – Land Cruiser-Specific Underdrive Solution With limited options for added crawl and low-range gearing in the Land Cruiser world, we set out to bring the proven strength, versatility, and compact design of the BlackBox to a platform that truly...northwestfab.com
