Builds H55/Splitcase into 02/79-40 Series (3 Viewers)
Finally was able to get the skid plate for this fabricated and installed this weekend...
More...
John’s truck still has the stock fuel lines on the frame. I modified them a bit to clear the newer style transmission mount that was installed. The rear mounting provision on the frame for securing the lines was now covered up by the angle used for the skid plate, so welded a bolt to the inner angle plate and used two rubber-cushioned positioning clamps to now secure the lines to the frame.....
This truck goes down the road so nice. It is a real pleasure to drive John!
Thanks! :beer:
Poser-
Nice work on the skid plate. What size tubing and plate did you use? Any plans for a transfer case drain area, or just drop it when needed?
The tube used was 1.5”x.120” HREW for the main cross tubes and hoop around the parking brake drum. Three 1”x .120” tube was used for the stringers between the front and rear cross tubes. .250” plate was then welded to the tube frame.
It is only six bolts securing it to the frame and the one bolt securing the fuel lines that need to be removed in order to drop it. Drain holes invite rocks and other things directly into the drain plug to cause unwanted drama with them.
:beer:
Steve,
You mentioned 'the little wonder air saw'? I have tried nibblers, air shears, tin snips, sawzall, really thin grinding wheels and even a hacksaw blade mounted in a hand held holder to cut metal and none of them are the cats meow. :frown:
Care to give some air time to the little wonder?
It looks like you have excellent control over where it goes evidenced by your cuts? How long is the stroke?
Thanks... Coolerman
Steve,
Thanks... Coolerman
Saw specs <---- this is a link
Just like any tool, there is a knack to it, but after you learn how to use/manipulate it, it is simply amazing what you can do with it.
There are many similar saws out there. Not all have a air restrictor/control valve built into them, but it would not be too difficult to put a generic unit on a tool that does not come with one, just after the coupler.
:beer:
Poser-
I'm getting ready to secure my brackets to the inside of the frame and wondered what the plan for removing the tranny would be for this rig? Is there room at the tranny hump to jack up the tranny to remove the center crossmember, or will the hump have to be removed? Obviously with a 73 I'd like to prevent removing the hump (seats, gas tank, etc.).
I'm considering welding one "L" bracket and welding tubing through the frame and bolting the second bracket to the frame to facilitate dropping the tranny in the future.
Any suggestions?
Myself,, weld the L on the left (driver) side.... the right one needs to be removable for ease in R&R trans/transfer......
Poser-
Any suggestions?
Did you notice how it was installed? ;)
The tube cross member, along with the gas tank (1979 40 series, 22 gallon external fuel tank) are preventing typical removal and installation of this transmission and transfer case assembly behind this 2F.
The transmission support brackets being removable or not has zero bearing on the serviceability of this unit in this application.
Depending on your engine and frame configuration, you may have more room.
:beer:
Hi All:
I'm sorry, "DaveWest5150," but I don't see how that could work!
No disrespect intended, but there is simply not enough room to squeeze in a F Series engine, H55F, and "split" t-case in between the front motor mounts and the mid-chassis crossmember on a FJ40 that came with the H41/42 four speed tranny!
Sure, if it was a B Series engine and H55F and t-case drivetrain it might fit. But, there will definitely be clearance issues with a 2F and a H55f and that mid-chassis crossmember!
Regards,
Alan
I have a modified 01/80 FJ40 with the 2F and H55. It all fits and runs with the the original torque tube cross member in place. It is a very tight fit. The real question is whether I could ever change the clutch if it needed to be replaced. The rebuilt 2F and H55 where installed as one unit through the front of the FJ40.
Welcome.
There is a pretty easy answer to this:
No.
There is not enough room to separate the transmission from the flywheel housing with the engine in place. The engine, transmission and transfer case assembly will need to be lowered and tipped down so that the engine is on the top of the front axle housing, so that the transmission and transfer case assembly can be unbolted from the flywheel housing and slid rearward, or the whole drive train assembly removed and serviced outside of the vehicle.
There were pictures of this very procedure earlier in the thread.
:beer:
I can get mine out but it's a real squeeze but then again i don't have the e brake on the tail shaft.
My mechanic has it down to a fine art.
shifter id plate
Steve, or anybody else that may want it.
I still have my custom 5-speed instuction plate that we had made years ago
(the one that fits on the glove box)
I have since gone the sm465/toybox/splitcase route.
let me know
Dave
Thank you for the offer Dave.
Shane, AATLAS1X out here sent me a new one that he had made, along with a new pocket door...I have installed these items, but just forgot to take/post up pictures...
:beer:
So since the rear engine mounts that fasten to the flywheel housing are no longer being used, I needed to figure something out for the passenger side mount that incorporated the slave cylinder mount. I was going to make something, but then found that a 60 series bracket appeared to attach in a similar location on the flywheel housing, but with 10mm diameter fasteners. I removed one that I had at the shop, drilled it out to .50”, and it fit like a dream, and works great! You can also see the 1982 and later style gear reduction starter motor that was installed and new 00 positive starter lead.
This is the only thing here that has confused me. Passenger side clutch cylinder? What years changed to that? If this is a late model mod, and you were going to do this with an earlier model could you leave the cylinder on the passenger side just as easily? Or is this a H55 requirement?
Was moved over there in 1975, iirc...
You can leave it on the driver (left) side as long as you have a rear engine mount that is configured that way currently...you will just need to modify the flywheel housing to fit the H55 as was shown in previous pictures.
:beer:
