With all the info in ksrunner’s thread, “H42 Stuck in Gear” I now have the confidence to pull the top plate on mine to look for my two shifting problems.
Problem # 1. Popping out of 1st gear.
It’s been doing it for years now and my solution has been the bungee trick to hold it in first gear. 90 percent of my wheeling is in first so I’ve learned to put up with it. Also, to use Pin_Head’s term, I don’t have that “Snick Snick” sound and feel when I change gears.
Problem # 2. Getting stuck in neutral.
Happened once a few years ago while on the trailer. Couldn’t budge it with engine running or not, and clutch in or out, t-case shifting ok but transmission locked solid in neutral. Pushed it off trailer and then it started shifting fine and did so for about two years. Still using the bungee though.
Then a month ago it got stuck again when I dropped into a hole in the trail. As it stalled, it popped out of gear. (forgot my bungee). Could not get it out of neutral no matter what I tried. When someone towed me out of the hole and about 20 feet it finally released and shifted fine for the rest of the weekend and on two more outings.
Then, this past weekend, on three occasions when I put it in neutral with engine running for a pit stop or beverage retrieval, I went to go again but it was stuck, locked up in neutral. But on these three occasions, with plenty of wiggling, it finally released and went into gear.
And, as luck would have it, my back ordered indent springs & balls came in from SOR yesterday afternoon so today I’ll take the top plate off and see if I can see what’s going on. Before dark yesterday I got the hump removed and the shift cane out. It’s got some wear on the end and figure it’s got to be at least part of the “stuck in neutral” problem.
