Rear Side AUTO UP Windows by yodaTEQ Gull Wing Hatch System
yodaTEQ
Design,Build,EXPLORE
Supporting Vendor
SoCal
Website
yodateq.com
EDIT: These are 2 photos submitted by customers that have the production version of the yodaTEQ Gull Wing Hatch System with Molle Panels. Please feel free to contact them for feed back.
Customer @Bimrunner install
Customer @mryanangel Install
VIDEO Published on Feb 18, 2015
GROUP BUY INFO
We will offer two models of our yodaTEQ Gull Wing Hatch System
#1 we are calling it the SEABIRD which will come with all the goodies including the Molle Panel System and of course the AUTO UP / one hand operation via our gas strut design
#2 we are calling it the GLIDER which will include all the same features of the seabird without the Molle Panel System but still feature our AUTO UP design
Along with these 2 models mentioned above I will also offer the ability to purchase single sides.
Both SEABIRD and the GLIDER will be offered in Aluminum and Steel and all parts are professionally powder coated to protection against corrosion.
When you go with our AutoUP/Gull Wing Hatch System you get yodaTEQ Quality
- This AutoUP Hatch System utilizes gas struts to open the hatch & hold it up
- Easy Install and NO DRILLING into your truck
- Your Hatch System has been CAD drawn and precision cut
- The Doors and Frames are Roll Formed to Match the Contours of the body lines of your truck
- We use flange gaskets on all the compression latches
- We use rubber bumpers on the heads of the grip screws that press against the frame's edge trim
- We use high quality compression lockable latches
- We use Weather Resistant Vinyl Edge Grip Seals on the hatch doors
- We use heavy duty edge trim on the frames
- All parts are powder coated to protect against rust or corrosion
- Our system has been field tested on various trucks with customer installs that include both driver and passenger sides.
SEABIRD - Complete System w/Molle Panels (Both Driver & Passenger side) includes:
(2) Hatch Doors
(2) Window Frames
(2) Molle Panels
(2) Color Plate for yodaTEQ Molle Panel
(16) Black Acorn Nuts
(16) Welded Studs
(2) yodaTEQ Name Plate
(4) Gas Strut Brackets
(6) Stainless Steel Hinges
(2) Gas Struts (hardware included)
(2) Weather Resistant Vinyl Edge Grip Seals for Doors
(2) Edge Trim with metal core for Frames
(4) Compression Latches
(4) Flange Gasket for Compression Latches
gull_wing_group_buy_prices-seabird-png.1128799
The yodaTEQ Gull Wing Hatch System will arrive fully assembled ready to insert into your existing aluminum frame and rubber seal for that factory look.
GLIDER - Complete System (Both Driver & Passenger side) includes:
(2) Hatch Doors
(2) Window Frames
gull_wing_group_buy_prices-glider-png.1128800
Back in June we put together a 9 Part Installation Video Series on YouTube that our customers used to make their your installation a breeze.
Contact me direct to place your orders frank at yodateq dot com or || 714 || 510 || 0770
Initial Post when this product was at its initial prototype phase
The yodaTEQ Gull Wing Door / Side Hatch has been going through field testing
PROTOTYPE VERSION 1.1
yodaTEQ,Jan 19, 2015
The Gull Wing Door replaces the rear window allows easy access to your load area via the side of your vehicle.
This allows easy access to your load area via the side of your vehicle.
I'm using the existing frame so it's easy to install and it gives it that factory look.
Proto-type testing has been going well:
- Removal of the frame
- Installation of my hatch kit (frame and hatch/door)
- Gas Strut worked great in assisting the hatch to open (one is sufficient)
- Seals did their job at keeping the water out
The latch I used was something I had in stock and although it works I'm going to try different latches. I'm also going to be doing some roll forming as to tuck in the door a little more
I love this idea!!! It's very clean looking! One thing I would like is two latches instead of just the one! Will make it harder for those thieving bastards to get in!
Looks good Frank. Sign me up. (Annnnnd cough cough boat sliders) :D
I think it looks great. What would the ball park cost be? I'm sure there will be lots of input on improvements or modifications but I think a simple cost efficient setup would be a good start.
I agree that two locking handles would be great! I guess it depends on the locking mechanism on the single handle. IMO!
Latches can be expensive so I'd recommend options for either one latch or two. Two is extra security from prying open.
I'd be in for one made of glass that can only be opened from the inside :)
That'd defeat the whole purpose of it! I'm really diggin' this. Hope price is doable.
Awesome!!! I have been wanting one.. Hopefully it wont be to crazy expensive.
I have these latches on there way
They can be closed and locked or just latched closed so it's convenient when you're wheeling/camping. When you leave the vehicle unattended you merely lock them both
My goal is to make these affordable so WE can all be able afford them. @FloridaFJ80 I promise they will not be "crazy expensive"
Question: Would you buy 2 as a set or only need or buy a driver or passenger side?
@bmac1996acc I need 6-8 minimum buys to go back into production on the sliders. Talk to me via PM and we can start a GB with Fastenal Shipping
I thought these Gull-Wing Doors were a great idea when I first saw them in 07 on Robby Gordon's H1 Chase Trucks.
Optional screen inserts for those that like to sleep in the back!
I would buy both sides to keep it symmetrical.
Great job Frank, I like! I've seen the WagonGear flip up windows in person. They're awesome, really well built. If I had money to burn I'd love a set of those but realistically I don't.
Here's an idea - is it possible to make a flip up window using the stock sliding windows? Reason I ask is because some of keep our dogs in the back and they like to have the window open. Can't really drive down the freeway with the window flipped up I imagine. Or perhaps make it a quick release system to remove it entirely?
Cool idea man! My buddy Scott integrated rotopax fuel cans into the back window of his JK. Maybe a future model could include a recessed pocket to fit some extra fuel. Another option would be to have the hinge on the bottom on one side for use as an extra shelf/tiki bar while camping.
Great point Jose. I had you and all us dog lovers in mind with the doors being removable via a quick release and detach the gas strut. That way man's best friend can enjoy the breeze.
or the Joker
Not needed. Frank is using an easily cut material so no reason why there can't be a doggy door IN the hatch.
