Pretty good set up for what exactly? What are your plans for the new configuration?
Color me crazy, but I'm likely going to split time with a lowered twin turbo coupe to do life here in crazy LA. The lease on my trusty and frugal Prius C is up soon. While I loved its bulletproof reliability, size and economy, there's zero excitement being behind the wheel.
This is actually my 4th Toyota truck all lifted with bigger tires. 2UZ-FE 4R, GX470, a SEMA Land Cruiser from a few years back... always wanted an FJZ80 and the solid front and rear axles. I will occasionally use it to explore the outdoors.
So if I were to stuff the typical 315/75/16s, is it overkill to go 4" high? I like going with Slee's kit because I know it's put together by a reputable dude. I would also re-gear so open to advice on which brand and which shop in Socal could handle this install job.
Kit Includes:
2 x SOF4FM Front Coil Springs
2 x SOF4RM Rear Coil Springs
2 x N60070L Shocks
2 x N60071L Shocks
1 x SD24 Steering Damper
1 x Slee Front Caster Plate Kit
1 x Double Cardan drive shaft.
1 x Front Sway-bar Drop Kit
1 x Rear Sway-bar Drop it
1 x Front 2" Bump Stop Drop Blocks
1 x Rear 2" Bump Stop Drop Blocks
1 x Set Stainless Steel Extended Brake Lines
1 x Front Panhard Rod
1 x Rear Panhard Rod
1 x Set Adjustable Rear Upper Control Arms.
2 x Breather Extensions
1 x Emergency Brake Cable drop bracket
Something like this would be nice:
Thanks, all! Esp the pics.
