Builds Gerry's Build thread: "If it happens again I'm buying an Abrams" (17 Viewers)
Read through this entire thread over the last few days, great inspiration for the LX I picked up recently (only a few thousand miles more than yours, lol). Also good to see someone local - you're in Woodstock too? Would like to pick up one of your rear hatch storage systems after I knock out a couple more items on the to-do list.
That's awesome! Yup, I'm local. In Acworth but just 2 intersections from Woodstock. Hit me up anytime.
Also, what's the Benz connection?
Sweet! Sounds good. I'm just further down 92 near Neese. I'm Ben Z, hence the name - but big into 90s German cars. They're just all Audis lol.
Little updates, here are some.
Gerry's been experiencing this roughness/ vibration for a while. It's not so bad that I think anything is being hurt by it, but it's ****ing irritating and I am Captain Obsessive when it comes to this stuff. So as mentioned, I pulled the front shaft and we drove to Galveston (ew) and back with no big issue. The roughness was decreased, but not gone. OK, we'll touch on that more. Trip was great and Edgar loves the beach.
So we've been driving in RWD for a few weeks now. I don't love it. Due to the roughness I'm avoiding, the idea of a part-time kit makes sense, but honestly, the trucks just don't drive as well in RWD. I miss my front end.
The other day I decided to isolate the diff by pulling off the front hub flanges. @LJE whipped me up a set of hub covers so I could run around like this for a little bit and feel it out.
I'm happy (happy? Am I?) to report that the truck feels much smoother with the diff isolated. This tells me there's something between the flanges that is causing this roughness, and it's something that spins while the flanges are attached, but not while they're removed. OK, so bearings and the actual gears inside. Cool, other than those being the pricey parts. CVs are relatively new OEM and have pretty much only road mileage on them. Wheel bearings feel very smooth. What does the hivemind think?
While all of my friends are in Colorado at the Cruisers on the Rockies event (which I'm sponsoring this year!) I finally got around to knocking out some little projects that I've been sitting on.
First up, the center console organizer from Alex @LJE . I may have bought the first one, but it's been tucked in a map pocket for a while. Decided to grab a few EDC items that I knew would be handy. Little multi-tool with some drive bits, torch lighter, sharpie, pen, and a flashlight (not pictured). This is a great accessory and if you don't have one, you should.
Then I did my battery terminals. I've had this on 'the list' for years but was inspired by @LJE's printed terminal cover. The material is soft like rubber, works great here. Terminal is Moreoso brand, #74098.
What's next? I think a speed sensor is going out. Over harsh bumps at highway speed, it'll make the speedo jump around. My fuel gauge is also starting to slow to react when refueling. Likely the sending unit, easy job. I also need to pull the front diff out and figure out what's not right inside.
Mileage is 359k. She's getting old, but she's still amazing. My Ms drives Gerry almost exclusively, and is just as attached to the truck as I am. Her own car never goes anywhere and takes up my garage space. So, we're selling the 560SEL and the Camino, I'm getting a 570 and she's getting an LS460. Gerry becomes extra car/ camping truck, but not going anywhere for the foreseeable future.
Could be the backlash in the diff? Other than that, maybe the bushings
I figured it wouldn't be the bushings, I know your reputation for old maintenance items hahah
20 year old, aggressively wheeled trucks with 360k on them are supposed to be factory perfect, right? 😄
Replaced the transmission speed sensor with a new Aisin today. When I pulled the old one, the connector was full of ATF. Cool, that'd throw some issue. I cleaned the harness side with electronics cleaner and installed the new one.
Speedo is still jumpy over harsh bumps. :bang:
Mileage is 359,5xx. We'll cross 360k on a trip this weekend.
I NEED that center console organizer! When will those be available?
You can buy those direct from Alex 😎 @LJE
And you definitely should. It's awesome. I even used the Leatherman from mine when I was installing my battery cap.
I jokingly put chapstick in mine when I first set it up. Holy crap - the wife and I used that ALL THE TIME out in Colorado. It was so nice for it to have a dedicated home, hahaha.
