At 210k I decided that it was probably time to replace the fuel pump filter. This is a
job.
Here are the parts I needed for my '97.
Filter, Fuel pump 23217-16490
Gasket, Fuel junction 77169-60010
Clip, Fuel filter 23219-03010
Gasket 90430-12026 x2
Tools needed:
Ratchet and small extension
8mm, 14mm, and 17mm sockets
Philips screw driver
Small flat head screw driver
1. Remove the second row seats and door scuff plates.
2. Fold back the carpet to access the Floor Service Hole Cover.
3. Remove the cover (3 screws).
4. Clean the area so that no dirt or debris falls in the fuel tank.
5. Disconnect the fuel pipe and hose from the fuel pump bracket.
6. Remove the union bolt and gaskets, and disconnect the outlet pipe from the pump bracket.
7. Disconnect the return hose from the pump bracket.
8. Remove the 8 bolts, remove the fuel pump assembly.
9. Gently pry the fuel pump filter clip off the bottom of the fuel pump with a small flat head screw driver. Gently pry off the filter .
10. Remove the gasket from the fuel pump bracket.
11. Installation is in the reverse order of removal
Edit: Added additional part numbers.
job.Here are the parts I needed for my '97.
Tools needed:
.Edit: Added additional part numbers.
