cps432
You know, all this is getting complicated. When I was in high school I used a bamboo stick to check how much gas I had in the ‘66 ford pickup truck. I only ran out of gas once. okay maybe twice…
I don't have the temper (or hatred for technicians) to be an automotive engineer that's for sureYou know, all this is getting complicated. When I was in high school I used a bamboo stick to check how much gas I had in the ‘66 ford pickup truck. I only ran out of gas once. okay maybe twice…
I would offer that the bottom LINE of the fuel gauge represents being on your "reserve" and that E really equates to empty. That might be the offset that is messing up your "full" calibration. If that works you could just include a note about that in a spec sheet shipped with each order: "Please note that when you reach the bottom hash mark of the fuel gauge, you have very little fuel and should fill up as soon as possible - E really does mean EMPTY."Oh yeah I remember reading through that thread. At least it was a fairly simple fix for that one once you found it.
So it would appear that the voltage regulator is now too low, as my second gauge picture in post #4 is where it sat (after adjustment) with 4.25 gallons of fuel in the tank. here's where it sat after topping off the tank this evening:
Also for reference, here's where my temp gauge was after a hard 20-mile run on the freeway with the AC going in 85° temps. Granted this is just slightly under what I would consider normal, but I know my engine is running warmer than it should be due to I suspect just overdue cooling system maintenance (though I suspect now it's really not as close to overheat temps in 90+° temps like I had considered before). To guesstimate, I expect it should have been sitting right at the third line up from C or perhaps right at the upper edge of that line.
I'm suspecting that there's very little reserve designed into this system and when the gauge is on E, you're sucking air. Seems odd that Toyota in the late 80s would do that, given a lot of other automakers designed a small reserve into their systems. Then again I could still be wrong. I just won't know until I start fiddling with actual resistance readings of the sender and compare those readings to what my gauge shows.
So my next plan of action is a bottom drain, then add fuel a half gallon at a time with a multimeter connected to the sender lead at the gauge connector in the dash and to a reliable body ground. Once I reach 120Ω and see how much fuel I've put in, I'll plug in my gauge and see where it's sitting. If it's bottomed out, I'll dial up the regulator until the needle moves and then slowly back until the needle just barely rests on the lower limit. Then another highway run and fill-up and see where my gauges are at that point. This will also tell us if there's really any reserve designed into the system once the gauge is on E.
You're absolutely correct on your second point. Since both the fuel and temp gauges share the same output from the voltage regulator, adjusting the voltage down will result in both needles reading lower; same with higher readings from higher voltage.I would offer that the bottom LINE of the fuel gauge represents being on your "reserve" and that E really equates to empty. That might be the offset that is messing up your "full" calibration. If that works you could just include a note about that in a spec sheet shipped with each order: "Please note that when you reach the bottom hash mark of the fuel gauge, you have very little fuel and should fill up as soon as possible - E really does mean EMPTY."
That offset error could also be showing as a lower reading on your temp gauge as well since the two are tied together.
Had another thought after yesterdays couple of posts: the calibration procedure could be totally different on a 60. Maybe not, but it's a possibility.
I agree completely, for the same reasons you stated. I must admit though I'm surprised that's the case, but it definitely seems to be a good thing.I would much rather have “empty” be at a hash mark than a big letter “E”. What part of the E? The top edge? I’ll run out of gas once the needle passes the E? Maybe empty is at the center of the E?
See what I mean? Way too inexact. A hash mark is much better and it seems like Toyota is telling you this! Even if full ends up having the needle well up by the “F” that’s fine, it’s far less critical than knowing when you’re empty!
Yes the documentation and installation/calibration manual will be the next big challenge, since I'll want to make it as easy to follow as possible. I still have the list of folks who contributed to my GoFundMe when I first started the project that if I can get a hold of them will get the earliest samples and I have a couple "beta testers" lined up to demo early units and give me feedback on the product and documentation.@Spook50 I think as long as the 1/2 & full indications are reasonable you should set the empty reserve wherever you want. I assume your product would come with documentation so all you need to do is make it clear to people where exactly "empty" is (the hash mark versus the "E") and how much reserve they have at that point, and you're good. Personally I would agree with you that having more reserve is better. Three gallons seems good: two gallons usable and one gallon below the pickup tube. Two gallons gets you 18-30 miles depending on driving $ motor tune conditions. That's better than one gallon which could be as low as 8-9 miles of range for some trucks.
Where was the gofundme? I missed that?Yes the documentation and installation/calibration manual will be the next big challenge, since I'll want to make it as easy to follow as possible. I still have the list of folks who contributed to my GoFundMe when I first started the project that if I can get a hold of them will get the earliest samples and I have a couple "beta testers" lined up to demo early units and give me feedback on the product and documentation.
I need to correct my statement from my previous post about the needle readings if I set the regulator to read the bottom hash mark at 3 gallons: It will cause the needles to read LOWER, not higher like I stated. Now if they're not too low, that should still be okay. I'm considering making a quasi test rig with my deep fryer (don't laugh) so I can have a controlled test environment for a temp sender and verify readings on the temp gauge as well (engine operating and overheat indications mostly). I want to make sure that with the fuel gauge set appropriately, the temp gauge would have a reasonable indication.
I deactivated it several years ago, but I think it was late 2013 or early 2014 that I had initially done it. I ran it for a while to get up some initial R&D funds for components and such, but once my divorce got heated up I deactivated it because I had to focus on that and the subsequent custody battle. Now I'm just fighting to pay my mortgage and keep my 62 maintained while doing what I can as a single dad to get this project finalized after ten years and keep doing my window relay refurbs.Where was the gofundme? I missed that?
So far the extra input has been great. Once I finalize this step, the next is prototypes and tweaks to see if I can make it work for 24V Cruisers, then finalize the PCB design and component BOM, documentation, and with any luck an initial production run after that.Very similar situation here, except my $h1t hit the fan in 2016. This is a really good idea and you're really close. Let me know how I can help get it over the finish line.
