Wax those leafs before you reassemble.1st set of springs painted. Waiting to see them dry to see if I need to change the process. Hoping the surface will self level and smooth out when it's dry
There are the nylon pads that I will be putting back in. Were you referring to those or to an actual wax type product?Wax those leafs before you reassemble.
Actual wax, post 315:There are the nylon pads that I will be putting back in. Were you referring to those or to an actual wax type product?
Thanks
Thanks for the input but I could not justify 3K on a used engine with 100,000 miles that has no warranty and I have no history on. Did anyone change the oil? Did they just beat the s*** out of it at every light? No clue. I think the 24 month/100,000 mile GM warranty is worth every penny of the extra $2000. Besides, everything else going in the drive train is either new or rebuilt so why take a chance on the engine. I am hoping to never have to pull anything drive train related out for the next 20 years. This is a daily driver, highway runner, and weekend trail rider. No mountains of rock, no bottomless bogs, etc......that kind of fun ended for me 20 years ago. You did convince me to go with the newer technology and after watching some Holly videos of the Terminator X install it did look pretty easy. Many times it's hard for us older folks to consider something other than "old school" but with all the input here I think the newer style motors was a good call, thank you.dude, skip the crate long block, get a complete one with 50k-100k on it for 1/2 the money, spend the $3k savings on something cooler, like a pair of ARB's and some really good shocks/
What did you use for your motor mounts? I see that TrailTailor used some factory style mounts.You will be definitely be happy with it, i can assure that.
Im hearing about people being blocked more and more these days.. strange things going on.I'm working on a new bracket kit right now to use Trailblazer V8 mounts. not much of the OEM GM mounts will clear the narrow frame rails using GM brackets that I'm aware of. Trail Tailor has me blocked so I don't see his stuff
Having run Holley Terminator on my 454 Chevelle for years I can tell you to really get it dialed in, you will likely have to pay someone to tune it for you. The computer will get it like 80% there on its own. I had a couple nagging issues on my Chevelle that cost me a dyno day to get ironed out. the smoking gun for me was that my ECU wasn't at the right software level and the latest version fixed a bug.
Yes! Both my 40s would “snap” into the straight ahead position because of the worn races…. Not certain why… most common steering position?Has anyone seen had this happen to their races (Koyo 303030) ? When I disassembled the knuckles everything had decent grease and nothing was dry other than the exposed outer surface of the knuckle balls. I would estimate these wear spots to be 0.003"-0.005" deep. Both upper and lower races had the same effect but the lower ones are the worst. The axle is from an 02/1980 FJ40.
Well then, if there is actually a cover that will bolt onto it so it does not look so Damn FUGLY I'm good with that. Do you happen to have a link to a picture of the cover you're speaking of? I guess it would help to be able to show people what I am looking for.Keep the truck intake. It will make more power at lower RPM and you won’t have to mess with your accessory drive to accommodate the throttle body being 4” lower. I went down that road and it was a complete waste of time. Just get the nice engine cover from a 2012-up truck and clip it on.
Im glad that crate motor comes with intake, rails and injectors, water pump, alt/pump bracket, thats the stuff that usually nickel and dimes you to death.
