Hi, I would appreciate help with my query. FJ45 not run in 7 years. Put on new fuel filter and fresh fuel. I can see fuel in carb window. Starter turns engine but no start. There was no spark at plug and no spark at HT lead. I put on a new coil. Also replaced ignition switch. With new coil and ignition switch still no start ??? Still no spark from HT lead with new coil?? My coil has external resistor. Primary, secondary and resistor resistance all seem fine. With the ignition switch at “on” and using voltmeter I have 12 volts. I have not opened distributor. I would appreciate any suggestions on what I should do next to try and get the FJ to start. Thank you.
