- Joined
- Dec 12, 2006
- Threads
- 79
- Messages
- 3,667
One of the many adjustments we are making is to the header flange.
We had to grind a small amount of material off of @bottombracket’s “Barney”!intake manifold for the lower inner mounting ears to fit the v1 header flange.
Downey's original installation notes state that some customers should expect to grind material off the flange or the manifold ears to make it fit.
We made minor clearance adjustments to the flange so grinding wasn't necessary. Then on @Dianna’s truck, we found the intake manifold didn't fit the original flange or the v1/2 modifications ether but Dianna's was far worse than Galen’s “Barney”.
Ultimate took a die grinder to the lower inner "holes" on the V2/V3 prototype. This rounded off the holes a bunch and we lost so much material on the inside that the standard washers had only a small amount of "grip" or overlap on the exhaust flange. We didn't like the looks of that.
So @S14B23Racer took the CAD (DXF) cut lines for all the versions of head flange that we've gone through and laid them over the top of one another starting with the original Downey/Mark's flange.
He then photographed and measured the gaps and compared how the holes and bolts and washers lined up with the intake and header flanges and laid out a new cut line for the header flange.
Instead of a large radiused "hole" cut, he notched the bottom of the lower bolt holes so the aluminum intake ears will sit into the notch.
He then cut a few prototypes out of acrylic on the laser and I think it works very well.
If it checks out on Dianna's truck, we’ll use it instead of the previous Downey/Mark's pattern.
We’re getting very close to being able to take actual orders.
