FJ40 & FJ60 Alternator Restorations (4 Viewers)
Probably, post up some pics!
Nice work!!!
Do you have any cores? My 79 40 has an aftermarket alternator I would like to change out.
Can you restore/rebuild a smog pump for the same?
Nice work!!!
I do have a few cores. Send me a pic of what you’re looking for (plug, orientation, etc).
Not doing smog pumps right now.
Here’s one for @andybudge that came from pardion’s stash.
Before:
After:
Here’s an FJ62 unit for @techster82 to use on his 60. We scrounged up an FJ60 pulley for belt alignment.
He also got a new internal regulator, which fixed the broken plug in the back.
Check out @caboulto ’s beauty after her mani-pedi at the alternator spa...
@FJ60Cam I'm looking for a 27020-61070 (55 amp FJ60 alt) to put on my '77 FJ55. I can't find one on the web and was hoping you or @pardion would have a core that you could refurbish for me. No rush but it's on my list.
The PO had @Trollhole install A/C and I assume at the same time installed a Remy alternator. Unfortunately the alternator cannot always keep up when the A/C is on and typically/often/sometimes drains the battery. It's a bit of an intermittent problem but I figured I would change the alternator anyway to an internal regulated type and get some connectors from @Coolerman to wire it up. From everything I've read, 55 amps is OK to use with the OEM wiring and meter.
Finally sent my old fart alternator on its way for a trip to the spa. Can’t wait to see the results! Thanks Cam. :cheers:
My FJ40 is equipped with electronic ignition, but I am different than others BC I travel the SE Asian Islands and ship y FJ40 by ferry. Recently y cruiser failed and I had no parts shop. I a native American from Texas. I was driving along and y electronic ignition failed. Stuck on side of road, no idea where to get parts or help. Finally had it towed and points put back in as original and alls great. So I have coe to the conclusion if you upgrade to Electronic Ignition, then buy a 2nd complete set for spare parts, or whats the other option? Points are simple for sure. Give e your thoughts pls.......
Here’s @tstepp920 ’s and @red66toy ’s alternators with the dust wiped off:
Thanks guys!
also CAM , While NOS " Presious " is Getting hew Yellow Anodized Riveted Parts tag Hand Buffed ....... 🤣
I Heve Little Sister with The Intact FOIL PARTS Tag too .....
can i send her in today's mail ?
