- Joined
- Jul 22, 2012
- Threads
- 583
- Messages
- 16,394
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
210 isn't terrible. Sounds like it just has air in it. Go drive it
Thermostat is brand new, and only fits in one direction. I may just need to burp the coolant system more effectively.Bad/Incorrect/Upside down Thermostat?
Fingers crossed its as simple as that!Thermostat is brand new, and only fits in one direction. I may just need to burp the coolant system more effectively.
Yeah. I’m underwhelmed haha.wow. that is definitely a rare one
I always thought I just had that kind of luck. I had a teq one fail to open when @mattressking and I fired up my rebuilt 2F. Scary. But easy fix and no harm done.wow. that is definitely a rare one
Runs very well! Tons of power. Amazing power steering. Brakes suck for some reason. Im unsure why but it takes a lot of pedal pressure to activate the brakes well. It also has a few other gremlins that need to be sorted but it drives very well and VERY fast.How’s she been running?
Im using an alternator that has an integrated vacuum pump, just like the original 12HT. Whats interesting is that my FJ60 has a 12HT, and the brakes are amazing.How are you making vacuum for the power brake booster?
Good thoughts. Im going to throw a vacuum gauge on my FJ60 and compare it to the 40. Appreciate the thoughts.Do you have a vacuum gauge and compare the 60 to izuzu pump?
Yrs ago b4 longfields, I swap a narrowed dana 44 in the front. It had bigger calipers than the 40. The stk disc brake master was a 7/8" diameter and didn't push enuff fluid. I had a low pedal and could pump the pedal for more height, so swapped in a drum brake 1" diameter master. I say this cause, if you have a decent pedal, it's probably not the master. Maybe leverage, but I doubt it. The power booster should be enuff assistance.
