FJ25 (and some early 40) Part Numbers (2 Viewers)
I dont know if FJ25s have the vent under the window like my 64/65 FJ40 does but here is the part number for it: 56413-60011
Chase, is that for the gasket or the vent itself? The gasket is a little different on the 25, but the 40 gasket can be made to work.
:doh: , I totally meant to say that it is for the gasket.
I have a few different numbers. These were from the F120 partial gasket set that I got from Mark's Offroad.
Crankcase Gasket 11312-61011
Timing Cover Gasket 11328-61010
Valve Cover Gasket 11253-60010
Thanks guys! Added new numbers.
I have one each part number 90947-02006 brake hose that will fit front and rear brakes on an FJ25....if I'm reading the code on the hose right it was made in 8/97...does anybody know what the "real" application of this hose is so maybe we could get them in an emergency from the NAPA in West Bum Egypt? Or should I just bug CDan and spend alot of money on stuff for the 450 while I have him on the 'phone?
That particular hose (and very same part #) also doubles as a clutch hose for a mid-late 1960's FJ40. That's probably why dealerships still have access to it. But, not sure if NAPA would carry it.
https://forum.ih8mud.com/showpost.php?p=760297&postcount=128
ahhhh....while in super efficient search mode I blew right that part....
Added transmission and transfer bearing numbers.
Johnny-
Looks like SOR is not listing them anymore. The number was 080-21-E-U 1958-1961 "USED", note the hyphen between the 21 and E which is a different part than the number you listed. Not sure if they don't sell them, but they are not in the price list anymore.
They have a 23mm hex instead of a 21 mm hex, finish was white metal.............probably were cad plated in the distant past.
https://forum.ih8mud.com/showthread.php?t=46512
Added timing gear numbers to replace fiber camshaft gear:
Timing Cover Seal 90311-45069 034-29A Beck-Arnley 052-2144
Crank Timing Gear 13521-60010
Camshaft Gear 13523-60030 (Steel replacement for fiber gear)
Phil, you just looking for a replacement, that works or original? I'll look tonight, I think I used the heater type one and had a thread in straight hose connection rather than the T style, otherwise the same.
I guess I'm wondering if anybody has tried to find an original no heater water pump? I don't know if I've ever seen one, but I'd like to give it a try as I don't plan on having heaters....I imagine it is the bodies that differ, maybe guts are the same? '68-73/4 pumps should work though, huh?
Added the oil lines from Bill: 90923-03001 SOR# 026-15A
Voltage Regulator on my 61 FJ40 with generator:
27700-30030
Does the steering column seal work with column shift trans?
27700-30030
Bill is that voltage regulator still available? The steering column seal was for the 25 with no column shift so it won't work for your 40.
I will let you know in a few days. Used the part number that came off mine and the parts search link and the number came up valid. Giving it a shot to see what comes in.
Is there a part number for the column seal w/shift arm?
I don't have a Toyota #, SOR was 098-22A. I may have one if I wrote down the number, let me look in the loft, remind me if I forget. ;)
