FJ25 (and some early 40) Part Numbers
Rear exhaust hanger: 90917-08004
I pulled all the numbers from here to order my tranny and transfer rebuild, seals and bearings. I ran into a problem finding bearing # 97103-06306 NLA
Found the toyota forklift cross over part #
87103-76003-71
Thanks, Mike
Yes everything with the vent. This happened to go in a '62 frame with aftermarket glass that was probably cut a bit large.o_O
If you run across a part number.....post it here or PM me and I'll add it to the lists. Big disclaimer........many of these came off 40 year old packaging....combined with my lousy notetaking.....could mean I might have made a mistake. Just because there's a Toyota number doesn't mean it's available either.......... ;)
Got a part number? Try it out here.
Feel free to comment and chat about part numbers here.......I don't mind, but will go through occasionally and weed out stuff that doesn't need to be permanent. ;p
Hello, do you know what is the correct engine for a 1960, 125 or 135? Thanks
John, I'd have to check on the F135 date, but I think it's referenced in the TSB's as either a date or engine number...in '59? (maybe I'll take a look later and get sucked back into this rabbit hole).
I'm not sure on the windshield #, I just installed the one I've had in the attic for ten years.
I think it was when the MandM 25 Automotive was still active I bought a couple windshields. They had a new one still in the box which is why I bought a few before they were NLA. Guess they are still around but certainly have gone way up in price. Between the FJ28 which is here in Phoenix and moving #14 around a bunch I'm in fear of getting sucked back down the rabbit hole.
Looks like all 1960's would have a F135, pretty sad this is the stuff I remember:
Hello Everyone,
Any info on this Denso Generator please ?? P/n isn't clearly visible ***00-60040 .. Off from Early 60's F engine .. 63 probably.
