Builds FJ 45 Extended Cab Custom Vehicle Build Finally Begins
All the parts are in so it is on it's way to get the 4:88's, Detroit in the read and an ARB up front.
Looks So Much Better! Lowering it a little was a good call.
Installed my Holley350 and throttle cable setup back on it.
I will eventually find all the right parts for the other carburetor but I need to move this around to different locations. Exhaust shop, Gear Shop, etc. It was begcoming a pain using one link to move different vehicles.
I also installed a new fuel pump.
Looks Wayyyyyy better amigo..
COOL!!!
looking at the bumpstop pic .couldn't ya turn the bumpstop upside down compared to it in the pic and make a plate and attach it to the top of the u-bolts and have it bump up against the frame ? instead of attaching it to the frame and bumpimg into the u-bolt plates. .
Well I did a few things to it on sunday.
I cut the front U bolts and am pondering the bump stops and mounts.
I'm thinking that is the easiest. One reason I was going to mount on the frame is that the spring plate is a bigger target to hit. If I mounted to the spring plate, the frame is small target to hit at only about 2 1/2" wide.
I'm also looking at the antiwrap bar for the rear.
Dan,
Did you see this one yet?
I know it's not X-cab, but has a similar look....err....to what yours was.:D
Full link here.
holy crap, the doc is selling his rig? i thought he had well over $200k into it last time i checked and that was well over a year ago............
Last time I looked on E-Bay it was at $5,600. Some assembly required. He was offereing a rebate for those who paid in cash.
