Builds Fix'n up the Land Cruiser..... (10 Viewers)
You forgot the redneck part. 🤣
I feel the same way but I won’t be as concerned we’re on we’re out in Death Valley for a week 😉
Your rig is way clean Paul !!
Can't wait for Death Valley...
Blue Sea switch donzo.
Holes cut n prime.
Paint dried and stainless #10/32, 2 1/2" bolts and lock nuts for hardware.
Freakn' perfect fit!
FINALLY I can say the under-hood mission is complete.
Holes cut n prime.
Nice! Wish I thought of that. I welded a bracket for my redarc isolator to the battery hold down. Works fine, but this is better thought out and executed!
Does that part number include the weatherstripping for all 4 doors? And did it come with the clips?
Not sure on the numbers at the moment, but anything that needed clips, all the parts came with new ones pre-installed.
Thank you. 🙂
1,100 shake down miles. ZERO oil consumption now, and oil so clear it's hard to see the level on the dip stick. 😀 On a 2 hour drive, 80mph set on cruise, into a head wind, she wanted to go faster. This is with stock gears and 10ply 35's. I am impressed. For the millionth time I looked over nuts and bolts after this shake down, some of which included washboard roads. Found the radiator bracket bolts loosened and snugged those down. Fluids up, grease applied and everything is snug. Applied torque paint on suspension points for easy visual checks. Almost ready for April's Death Valley trip.
1k oil change, then next one at 205k with a Blackstone sample.
I also was able to align the hood properly.
