Get the ARP studs from front range. The guys on PBB beat their s*** like no other and I have yet to hear of an ARP stud failure. Whether it be hub studs or steering studs.
Look nice ..
But the other studs from the hub cab ?
Bolts will loosen up again. Then you will shear them off..You know what I meant![]()
Why would you not use them?
If you feel you must upgrade, use toyota 100 series 10mm ones [which are the same as the diff carrier bolts in the housing] instead of the factory 8mm ones.
Even with 440hp @ the wheels, and 38'swampers.
quote]
I'm sorry, I ignored everything that you said after these words and "toyota" were used together. . .
Nice Buildup! id like to build a runner to beat on soon!
Maybe those Hex Bolts will hold up! i would not hesitate to run them! the only way to find out if they work is to try.. THe ARP Studs seem to work great, and/or the Hendrix Pin Mod!
Nice nice .. you make me lolhey all spotters need rest after hard spotters work
