pinion angle
Dolores,Co.
I have a 1969 FJ40 with Diamond axels and a SOA setup the rear pinion angle is facing slightly upwards when sitting on the ground, at full droop it is lines up with the driveshaft , it does have a Double cardon setup on the transfer case side . My question is having the pinion angle facing slightly up when sitting on the ground going to cause premature wear on the u-joint?
Any info would be appreciated. Cheers Dennis
I don’t know anything about Diamond axles. Perhaps @Firemedic831 might have a better idea?
I do know a little about the Diamonds . But a Diamond housing will have zero effect on what pinion angle you are running .
