The engine compartment looks better than average.
Looks maintained and driveable, hydraulics look nice.
F motor with alternator on left and oil filter separate with hoses but the better 2F valve cover.
I have a March 72 and it looks pretty similar.
Focusing on the stuff that is expensive or hard to find,
The power brake booster looks pretty good, probably a $350 part.
1F exhaust manifolds can get cracks at the inside 90 degree corners where the vertical drops meet the horizontal part.
If it is good that's a plus, to replace maybe $125.
Missing drum type air cleaner assembly would be maybe $150 to replace.
Missing emissions solenoid box on drivers fender that probably never worked anyway.
There should also be a charcoal canister mounted low on the passenger side inner fender.
I don't see the radiator overflow tank, also not a big deal.
On the body I'd expect to find rust in the usual places, back sill, rockers, back quarters.
The vertical seams are still there at the front & back edges of the rockers so not completely filled with Bondo.
Back fender wells are not cut, nice.
Correct doors with good rubber, all hardware and working windows is worth $500+.
Barn doors with all hardware, nice
Later short jump seats to accommodate roll bar that was not offered on a 72. I like the roll bar and short seats better.
The dash looks good not cut or buggered but has later 3 piece lower dash pad and radio cutout that is not on my 72.
Wrong front seats if that matters to you.
All in all it looks like a lot of good stuff and one that would be worth owning.
