Love the floor of the 40.
That's a great helper you got there....the 40 should be just about done by the time he's ready to drive!!!!
That bearing (on the third part from the left on your picture) went on really easy for me. No press needed, just some sockets and a vice..
Good progress, Mike ! Is this engine for the future Camper-mobile ?
The camshaft turns half the amount the crankshaft turns (each time the crank goes around, the cam only goes one-half the way around). If you did it wrong, you could be "180 degrees out". Either way, the marks must align at THE SAME TIME that cyl #1 is at TDC. Then if you rotate the assembly 2 times, it should all realign. Make sure that the lobes on that cam are in a position that both intake AND exhaust valves are closed at TDC.
You can also have the cam and crank aligned and have the distributor 180 out. Always start at the crank, verify TDC, then verify that the cam is set with both valves on #1 closed (TDC). Then do the distributor so that it is pointing at #1 plug wire on the cap when it is fully installed.
If you're unsure, start again at the beginning.
Wow, glad to hear you're able to recover from the slight mishap!
Regarding the camp shaft service bolt, this tends to confuse people a little. If you put the service bolt through both halves of the same sprocket before removing the camshafts from the heads, then you're all good. If not, no biggie since you can do this after the fact. Just pointing that out!
2 thoughts.
Spin the motor (on the stand) over and use air to blow out the holes.
If it were me I would reuse that head gasket, but I don't know anything about anything.....
I hear you ... The replacement ... its already been ordered as of 2 hours ago. I just want to hear what 2FPower has to say about torquing down a gasket twice.
Do not torque down the 1FZ head gasket twice.
If Beno says not to do it, then I bow to his knowledge.......
