Put it in rice
Once I had a Volvo C30 come through my shop after some window beating rain that had about 3 inches of water in the foot wells front and rear due to clogged sun roof drains, I wet vac’d out the carpet as best as possible but I wasn’t gonna spend the time pulling out the entire interior and carpet. I parked the car in the sun with the windows cracked the with of a pencil and ran the car with the heat on floor/vent for many hours had a pen style thermometer stuck in the crack in the window and it was 155 degrees in the cab, that car was drier than Hillary Clinton’s ………This is good suggestion. Humidity is a big problem. The longer stuff stays damp or wet, the less recoverable it is.
Using an ozone generator machine in the vehicle could also help keep mildew at bay.
A big dehumidifier suitable for a basement or garage is around $350-400 from Lowe's, Home Depot etc.
Bought one for a work project recently.
They need to be emptied daily, or set up with a drain hose.
I used a small one inside my current 80 when it was stored in a damp basement garage situation. (IH8ApartmentBuildingBasementGarages!)
Kept my 80 toasty warm and dry inside. And still pulled a surprising amount of water each day.
Yes the spark plugs were out for quite some time. I disconnected what I could in the engine compartment and left some of the water tight connections alone as the plastic is pretty brittle. After I changed the oil I would periodically fog the cylinders and jump the starter motor to turn the engine over. The distributor cap was off and I had cleaned all the connections. I pulled every fuse and relay. The fusible link connected to the battery seems to have done its job. I have replaced that pigtail. I swapped out the heavy gauge wire running from the battery to the starter as it was crunchy and corroded pretty bad. Even the interior door lights and dome light came back to life. The windows don't roll down and I still need to take apart the doors and sort all that out.Nice update!! Were all the connectors sitting open during this time?
New battery, surely?
Have you tested all the electronic functions?
Looking forward to more updates
